Seeking recommendations re: upgrading brakes ?
I just got my SVX back after 3 years of storage and then approx. $2,500 of work ... new valve covers & other stuff around there, new MAF, new TCU from ECUtune along with Stage1AV1 ECU module, installation of a transmission cooler, new spark plugs, tranny fluid flush and other sundry work.
Damn .. it runs very very nicely indeed ! And .. it's been garage kept since I acquired it in 1996 with 48,000 kms on the odometer (now 177K = 110K miles). Seats in great condition, sun visors perky, even managed to clean up quite nicely the driver's side arm rest where the Escaine always gets greased up from dirt and human effluent. The SVX has lived in Vancouver since new, so there's nary a hint of rust anywhere on the body and the underside of the car is completely clean ... clean ! I've had the car and gone this far .. lots of patience required to believe in this car's potential to say yes to the time and $$'s I've spent so far. And since it's now (FINALLY!) driving like a solid and hot-ass little coupe with new shift maps, etc., I think its worth it to address the braking. So .. if I want to take the braking on this car up a notch or two ... Any suggestions ? |
Re: Seeking recommendations re: upgrading brakes ?
OT's big brake kit? That's the most inexpensive one I can think of. Either that or going all the way for some Brembo's or Movit brakes. Then again, they are expensive as hell.
How about the big brake kit, dimple slotted rotors, rebuilt or new calipers (powdercoated), ceramic brakes, and some stainless steel brake lines?
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Link to additional information ... if you have it, please ? Would (in your opinion) just putting on good slotted rotors (or Bradi blanks) and new better ceramic pads be sufficient if I am not a hard-driving hound ? |
You could PM OT (Svxfiles), or go here to order: http://www.svxfiles.com/brakes.html I don't know if they're still available based on the message on the top of that URL.
The full upgrade kit is what I've been running for several years now. Very pleased with performance. Can be a little squeaky when wet/cold, but that's because I got the dimpled and slotted rotors. They work great for Auto-X (If only my sloppy stock suspension could keep up!) With regards to it being enough, it's been discussed on here before, the stock brakes are sufficient enough to get ABS to engage, which means a big brake kit is not necessary for better braking (tires would be the first step). The only real benefit the big brake kits offer is more surface area / airflow, to dissipate the heat, which means less brake fade on track days. From the way you describe your driving, I think OT's kit will be more than enough for you, and its a great price to boot.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
So, I guess I will have to source my own slotted rotors and pads. Based on what I've read, think I will go with Akebono ProACT ceramic pads .. So .. any one have any recommendations as to best sources for rotors ? ebay ?? .. I think given the way I drive I can probably go with Bradi blanks (again, based on what I have read in forums) but recommendations about sources for well-performing slotted rotorrs will be appreciated. |
I fitted EBC Redstuff brakepads, DBA slotted discs and braided lines on the front. EBC redstuff brakepads and EBC brakediscs rear...
FANTASTIC UPGRADE.....and looks much nicer. Now I just received some WRC 18 inch Subaru wheels made to order for my SVX.....so this will look awsome as well Quote:
