Old 06-20-2003, 10:58 PM
Henry
Bad coil pack -- HELP!!!
Intermittent stumble at idle, and it misses when accelerating in overdrive.
Should there be a Check Engine Light? Is there a way to tell which coil pack it is?
Thanks!
Old 06-21-2003, 05:31 AM
Re: Bad coil pack -- HELP!!!
Thanks!
what year is your car? if you have OBDII, then you might get a misfire code with a scanner. otherwise, search for "diagnostic connector" on here and find the procedure for the earlier models.
when mine was misfiring, it sometimes didn't throw a CE light - only if i was going up a hill and it did it for a certain amount of time.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 06-21-2003, 08:16 AM
Henry
It's a '93... 135k miles.
How can I determine which cylinder it is?
Old 06-21-2003, 09:18 AM
OBDII will tell you which cylinder. i don't know about the earlier codes - have you searched for them, and the procedure for retrieving them? i imagine it would have a separate code for each cylinder.
Old 06-21-2003, 04:36 PM
Subafreak's Avatar
Superbeast
Pre- OBD2 cars won't set a code for a skip. If its definitlly a dead skip you can try unpluging one coil pack at a time to find the bad cylinder. It will be the one that doesn't change the way the engine runs.
Old 06-21-2003, 06:29 PM
oab_au oab_au is offline
Just a point. If Henry is going to run the car under load on the road, to find the bad cylinder, it would be safer to pull the injector plugs instead of the coil plugs, so it does not run unburnt fuel into the cats. Should still be able to find the cylinder the same way.
One Arm Bloke.
Tell it like it is!
Old 06-21-2003, 07:00 PM
Henry
Easier, too. It's hard to reach those coil connections.
However, it's an intermittent problem. In the repair world there's nothing I hate more...
Old 06-22-2003, 02:24 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
could be other things
usually a bad coil pack isnt bad just at idle....
a stumble could be old spark plugs, bad TP sensor,
dirty or bad Egr valve, mass air flow sensor on the
verge of going bad, or even the crank trigger sensor......
Pick one or pick them all ....good luck
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
