Old 05-09-2009, 12:45 AM
Gamesy's Avatar
Gamesy Gamesy is offline
belt changing
i was looking at replacing my AC belt but the pulley's are right up againt the fan shroud, maybe cause the transmission is still out but anyone have have little to no room between the pulley's and the fan? or do i have to take the fan shroud off to replace the belts?
Old 05-09-2009, 06:54 AM
Manarius's Avatar
Manarius Manarius is offline
Re: belt changing
I pulled both the A/C and P/S belts without removing anything except the belt cover. I had plenty of room as well. There must be a good 3-4 inches between the belts and the fan shroud and that's plenty of room to get those belts off.
-Jason
-Obi Wan Kenobi
Old 05-09-2009, 09:44 AM
Re: belt changing
That is all I remove as well. No problem changing them with that removed.
Old 05-09-2009, 10:28 AM
Gamesy's Avatar
Re: belt changing
hmm maybe its cause the tranny isnt pulling the engine back or b4 previous owner somehow put new bigger fan shrouds in, oh well i guess i'll wait till after the tranny is put back in
Old 05-09-2009, 10:31 AM
Re: belt changing
Post a picture of that area. I wonder if something is different.
Old 05-09-2009, 01:43 PM
Re: belt changing
It is probably because the trans is out of the car. The transmission creates more wight on the back of the motor causing it to sit normal. When you remove the trans, you need to brace the motor properly or it will literally tip to the front...
Old 05-09-2009, 05:58 PM
NiftySVX NiftySVX is offline
Re: belt changing
The transmission holds the engine at a slightly downward angle. That is to say, the line that would represent the crankshaft of the engine it not parallel to the ground, the nose of the crankshaft is higher above ground level than the rear. The engine will sit flat without the transmission and the pitch stopping mont to hold it in this "slanted" position. Be careful that the radiator is not damaged by the engine unit hitting it if you get rough when installing the trans.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 05-09-2009, 08:38 PM
Gamesy's Avatar
Re: belt changing
if anything the shroud would be wrecked b4 that happens
Old 05-09-2009, 08:40 PM
Gamesy's Avatar
Re: belt changing
here's the pics of the gap
Old 05-09-2009, 08:51 PM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
Re: belt changing
Yep, that's way close. Just wait for the tranny =)
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 05-09-2009, 10:28 PM
Gamesy's Avatar
Re: belt changing
ya will be nice to get er up and running its been over a months since i bought it lol
