codes wont clear
ive been going through the process of checking and clearing my codes but they wont clear
the CEL keeps coming on Ill put the blue wire pin into the second slot from the left in the black connecter with the notch up and the ignition off. then ill turn the ignition to the on position and read the codes (32, 31, 37, 23). Then ill put both blue wire pins in the first two slots in the black connecter notch up and start the car and turn it off Ill check the codes again and theyre still there what am i doing wrong?
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
Re: codes wont clear
Have you investigated the codes? How long has the CEL been on?
heres what i have to look into:
31 Throttle Position Sensor or Circuit 32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX) 37 Oxygen Sensor (No. 2, Left Side, On SVX) 23 Pressure Sensor (Justy) im not very knowlegeable on the layout of the vehicle, that is, where these sensors are my CEL has been coming on with every drive for probably the last month or so
What I was trying to figure out is if all 4 codes started at the same time or if they've been adding up over time.
If they all happened at once then chances are there's nothing wrong with the sensors and you need to find out how they are all related. Perhaps there's a bad fuse. I would make sure of this first. Also check your battery (load test) and charging system (alternator). A weak battery can throw false codes. I've seen it happen personally. If the above are good then start with the smallest code (23). See if you can borrow a known working MAF sensor to see if it eliminates one or more codes. Work from there.
Try disconnecting your battery overnight and reconnecting it the next day.
After disconnecting the battery negative cable over night I would touch the disconnected cable to the other cable for a few seconds before reconnecting the negative cable back to the battery. Then before starting the car I would check for codes again. This will verify that the codes have cleared, (maybe) At the verry least it should. These cars are strange animals.
Keith |
a few weeks ago when i first noticed the light, i checked the codes and only received one for one of the O2 sensors so yes, they have been adding up Quote:
will do
