New Aftermarket Rods
Adds 20 whp per cylinder!!! 3.6L technology applied to EG33 Rod.
If you wanted phast, now you has. |
Re: New Aftermarket Rods
Sweet mod man! how did you find it?
Wouldn't you like to know!
J-Spec engineering is off limits to prying eyes. |
Sweet! So much for having to offset grind the crank!
-Bill p.s. was this in the ill-fated EG33 from the last Cumberland airfield autoX?
This was out of Hocrest's engine. Crank is screwed as it spun two rod bearings and is likely bent by this little gem. This was the #2 rod while the spun bearings were on 4&5. The engine rattled the bolts loose on the back of the oil pump and likely bled out the oil pressure and thus... bad things happen.
Tom |
Coool...
Can I have that one back?
-Bill
