CEL error 45 update.
For a few months now I have had a CE light come on, I decoded it as error 45 (atmospheric sensor fault) - replace ECU.
I opened up the ECU only to find no atmospheric sensor board in the ECU (unlike the USA versions). So figured that the fault lay elsewhere - the B67 pin 9 connection in the ECU was not connected to the wiring harness (this is where the atmospheric sensor lead goes out somewhere). So thinking to myself the only sensor that senses atmosphere is the MAF....so bought one from www.jauce.com for NZ$50 Fitted it today - now no more CE light !!!!!👌 Now I want to split open the original MAF and look around to see if there is a broken connection, is there a "how to" doc on opening up an SVX MAF somewhere.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: CEL error 45 update.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R Last edited by theflystyle; 09-23-2019 at 09:24 AM. |
Yes that is it - thanks.
Been running for over a week now and still no CEL - one happy owner again.
