Electrical Gremlin
My 96 LSi has had an electrical system which was operating FLAWLESSLY. Every bulb works, all switches operate as designed, alternator cranks out 14 V and I never had an electrical problem of any sort.
Last week I took my car to the Subaru dealer. I had a "check engine" light and it turned out to be Knock Sensor #1. I know the tech had to pull the alternator to get to it and whetever else was in the way. He replaced it, cleared the codes and all seemed to be well... BUT About 2 hours later I tried to use the front wipers and they didn't work. I figured somehow I blew a fuse and replaced it. Every time I put a 15amp fuse in the #2 slot (front wiper) in the fuse panel under the dash and turn on the ignition, it blows. I have no idea if there is a relationship between this and whatever the dealer did. I also have no idea where to start in trying to diagnose this problem. Currently, my rear wiper/washer and front wipers/washer don't work. As I said earlier, I never had an electrical problem ever. My wipers, front and rear, always worked perfectly. It wasn't until I tried to use the washer that I discovered the problem. Any help, insight or suggestions are truly appreciated.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-10-2005 at 06:59 PM. |
Any luck finding your electrical gremlins?
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
Take it back and make the dealer fix it cause they did it. And did you figure it out?
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I just cannot figure out what they did that would cause ONLY that one circuit to fail. Every other switch and light works normally. I thought that if they caused the problem I would have a lot more going on.
I don't think that switches normally fail, so I don't think it is in my wiper switch. Plus the wiper fuse blows when I turn the ignition switch to the on position (I see it arc in the fuse panel) This is when the wiper switch on the column is turned off. Its going in tomorrow so we shall see. I thought someone here might have insight on what to check.
