Drilled/slotted Rotors
I've searched and can't find the answer - how exactly does drilling and slotting improve performance of a brake rotor?
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
helps in cooling the hot rotor. i'd say slotted are better, because drilled holes weaken the rotor. they look cool, but unless you can afford to change the rotors as often as professional racecars do, they're probably not a good idea for the street. Porsche has the holes cast into the rotor during manufacture making them stronger, but they are pricey $$$$.
Other rotors are dimple drilled. In other words, they only drill 1/8 of an inch into the rotor (not all of the way through) which does not weaken the rotor as much as cross drilling. Some are slotted and dimple drilled. RaceConcepts have rotors that are that way. Just my .02!
- Ca$h |
<<On the porsche factory RACECARS they REMOVE these 'drilled' rotors and install NON DRILLED NON SLOTTED rotors. Why? More surface area for the pad to bite on, less chance for it to warp.>>
Don't forget they also use rotors that are about 5cm wider in diameter than OEM and about 2cm wider spacing between discs. They also use larger surface area pads. Doug
Then, I got a chance to purchase a set of drilled and slotted's for less than stock, and decided to do more research. Turns out that the sources I read were also against Drilled and slotted or drilled or slotted rotors . . . for RACING. However, they saw improvements in performance for the everyday driver and practically all reviews and articles gave them a thumbs up for the average commuter car. Believe me, I was "floored" as I read the various reviews. Needless to say, I bought the D/S rotors. I've yet to put them on the car (figured I'd wait for the current pads to wear out), although, the folks at the tire shop said I needed rotors. I bought the "Evil Twin" with drilled rotors already installed and the car seems to have better stopping power, but, this could simply be a difference in the rotors on "Patience" being old and the rotors on "Evil Twin" being relatively new. We shall see, when I make the switch on the other car. I also intend to get SS brake lines for both cars.
Here's a simple explanation of the slots.
http://www.appliedrotortechnology.com/index.htm If you want to see what the SVX ones look like check my personal locker. |
Re: Drilled/slotted Rotors
The drilling is to allow water to escape from between the pad and rotor. Used on mainly on motor cycles because the disks are open to the rain. It allows the water to be squeezed into the holes, away from the surface of the disk. The bike riders will know the feeling, of hitting the front brake in the wet, to have no reaction, so you squeeze harder, the water goes, the brake locks and down the road you go. On our road cars the disk is shrouded by the wheel, so the water is not a problem and the holes are not needed. Only solid disks should be drilled. Drilling vented disks interferes with the cooling, that the vents are designed to do. You would not drill holes in the impeller housing of a turbo charger as it would interfere with it's action. The venting between the surfaces works the same as the impeller, to pump air from the center of the disk to the outside edge to provide even cooling of the disk. Though you can get them in 4 different colours and with blue callipers they work fantastic at pulling a crowd. Harvey.
Randy,
Instead of naminig your SVXes 'Patience' & Evil Twin', how about 'Patience' and 'Imprudence' after 'Patience and Prudence'. Afterall , you were a DJ.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
Ahhhhh . . . mystery unraveled. Thanks for the info, guys.
the new rotors on the 911 twin are ceramic - don't know if they use them for factory racing, though. i'm guessing yes.
While we're here - can cryogenic rotors be "turned", or is this a REALLY stupid question? Ron(duh?)
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
From what I've read Ron they can be turned. Supposedly the freezing goes 'to the bone', so to speak.
At first I thought they might be on to something, but the more I think about it the more I think that they're probably as good as placing magnets around your gas line. I guess my biggest problem is that warping is caused by density variations and freezing isn't about to cure that. A better process in casting them would be the ticket. But the manufacturers are selling them like hotcakes at ridiculous prices already, why should they change anything?
