Lower control arm bushings worn?
I have a clunking noise when going over bumps and around corners that I think are caused by the lower control arm bushings which appear to be worn. Using a pry bar I can see that the bushings are cracked around their circumference. I have replaced the ball joints which were worn; this helped with the problem somewhat.
Is this a typical problem with the control arm bushings? Does anyone have any used control arms for sale that are in good shape? Is there a group buy available yet on the control arm bushings? Thanks, in advance. Ken |
Is the control arm bushings a common problem???
I have not got a reply on this yet.
Please someone reply. |
there was a group buy on control arm bushings..
you would have to go to the group buy forum or pm earthworm to see if there is any avaliable.
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Once there is enough demand there will be a group buy for these bushings. Check the group buy forum and add your name to the list if you are still interested.
thumps over bumps could mean sway bar links are worn grab them shake them and see if there is any looseness in the parts
