Old 12-31-2007, 03:55 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Here is the definition of a collector car in New Jersey:
"�� The vehicle must be less than 25 years old to qualify for Collector Vehicle Status.
�� The vehicle must have been manufactured in limited supply or there must be evidence that the model is currently in limited quantity.
�� The vehicle must maintain an operable odometer.
�� The vehicle’s chassis cannot be altered: High/low rise chassis are examples of altered chassis.
�� The vehicle cannot be a kit or replica vehicle, or be identified as a reconstructed vehicle.
�� The vehicle is not qualified as a street rod as provided in N.J.S.A. 39:3-27.27.
�� Collector Vehicles are subject to all applicable equipment requirements for year of manufacture and although not subject to inspection, they may be issued a summons for equipment violations if the required equipment is not maintained."
In addition to filing the application, paying the fee and submitting photographs, the following is also required for collector car status in New Jersey.
"All applicants must submit evidence from either the manufacturer, a recognized car club (on letterhead) or collector organization that the vehicle applying for Collector Vehicle Status was issued in a limited edition quantity or that a limited quantity of the original production run remains."
"The applicant must provide proof of limited use insurance: declaration page or insurance card, which indicates the limited-use status of the vehicle."
It gets you a waiver from biannual inspections, except for an odometer check.
"�� Upon receipt of the renewed Collector Vehicle Status Voucher, the vehicle must be presented to any centralized inspection facility for an odometer and insurance verification. Applicant will be required to provide their driver license, vehicle registration, collector vehicle voucher and proof of limited-use insurance to the inspector. With the completion of the verification process, a triangular-shaped Collector Vehicle Decal will be issued by the inspector, which will expire two years from the date of issuance.
�� If during the verification process, it is discovered that the vehicle has exceeded its 6,000 mile biennial limit or 3,000 mile annual limit, issuance of the Collector Vehicle status will be declined and the vehicle will be required to be inspected."
So, our certificate of membership should state exactly how many of the cars were manufactured, and how many were imported to the United States. In addition to our name, address, declaration of membership status, year of joining, it should also list the specifics of our individual cars, including year, model, color, and VIN. Probably doesn't need to list mileage. I think that would be very cumbersome to maintain, verify, and update.
Here is the link to the NJ Collector car status website:
http://www.nj.gov/mvc/Vehicle/collector_vehicles.htm
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 12-31-2007, 04:02 PM
John:
I just downloaded your form. I think it is perfect for my needs. I would donate $50 to the SVX World Network to receive such an official form. I am assuming that you can decipher the ordinal position of manufacture from the VIN, and that the manufacturing numbers per year fall easily to hand.
Tom:
I think we both have a little bit of a problem with respect to our deviations from stock, However, our mods don't show up on photographs, so as long as we keep the mileage in check, we should be OK.
Old 12-31-2007, 04:16 PM
crazyhorse's Avatar
242,000 mi on oem trans
This could get really sticky to administer, as you'd have 50 different criteria to adhere to.
The best way to handle this is with a "shotgun" approach. Any certificate/s should have all the info shotgunslade mentioned, plus maybe, a PDF document from SOA stating production #'s That way if your particular state won't accept the word of a club, they have a letter, on SOA letterhead to "back up" the facts.
Here in TN:Any individual submitting Form SF-1090, Certification for Antique Registration, certifying the motor vehicle is an antique. The vehicle must be 25 years old with a non-modified engine and body. An antique motor vehicle can be a passenger vehicle or a motorcycle; however, the fee is the same for both. ($26)
So collector status is out for the SVX for about 15 yrs. If it's modified, fugetaboutit!
As far as I can find, we have no "official" collector's status beyond an antique. That said, if you have an antique, you can run plates from the year of manufacture, legally.
"42"
Current Stable By Age:
Old 12-31-2007, 04:34 PM
New Jersey has Antique status for vehicles 25 years old or more. The Collector Status is only for low volume production vehicles, less than 25 years. The only thing it gets you is relief from inspections, and because the state is verifying the mileage limit, possibly a break on your insurance.
Old 12-31-2007, 04:52 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Florida offers an "Antique" plate at 20 years for any car. All it offers is a faded blue plate at a lesser price (not based on car weight). Even before that they don't care about verifying mileage (10 years? not sure). I would think this certification would be geared towards insurance.
I did get a Florida title for a '64 Ford truck that allowed me to officially own it without tags or insurance, as long as it wasn't driven on the road.
Gene
Gene and Ben
Old 12-31-2007, 11:19 PM
nextse7en's Avatar
nextse7en nextse7en is offline
Graphic Artist
Round 1
Patrick
1995 Ebony Pearl. S.N. 0001 "Araby"
JDM Power Mode Switch, Integrated GPS/Video Player
6Xk Miles.
1992 Teal - Sold to Mysvxrocks
[SIGPIC][/SIGPIC]
Old 01-01-2008, 02:08 AM
I like the way John had his numbers on separate lines so they didn't run together. Why is the Alcyone on the certificate? US models were not Alcyone. Just wondered.
Old 01-01-2008, 06:52 AM
Vehicle registration or Membership certificate?
All of the information people are posting is adding to the store of information needed before we embark on finalising any documents, and are very welcome for that reason.
I see one major problem with what forms are being proposed, particularly Patrick's and it is a complex or compound problem.
People seem to be mixing up the requirement for membership of a recognised club [which is personal to the vehicle owner] and a requirement to have a particular vehicle registered with the specialist club, VIN # etc. This seems to be the general object of Patrick's very nicely designed cert.
However, as I said earlier on in this thread, we need to simplify what documents we put forward to cut down on administration work on a yearly basis. I'm not trying to be negative here, but we need to keep it realistically achievable, as we don't have the staff of the state or government's vehicle registration office on hand here to keep track of changes of vehicle, address, ownership etc.
The first and primary requirement is a certificate showing membership of the Network, the dedicated club for SVX preservation.
If, secondary to this membership form, some insurance companies or some states also require that the vehicle is on a registry, then that has to be a separate form.
The reasons I believe that the vehicle registration form should remain separate from the yearly membership form are multiple, but primarily it is because members may have more than one SVX, and that some members are certain to sell or change SVXs within the year of membership, thus negating the legitimacy of the original issued cert.
Your comments please.
Old 01-01-2008, 07:20 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Would rims, front bumper lip, HIDs and other things listed in my sig be too far of a deviation from stock?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-01-2008, 08:02 AM
bwb3's Avatar
I agree Joe. I would also use some wording to the effect that (insert owner's name) has "listed" the following car with the SVXN. That way the administrators are not taking the responsibility of verifying ownership or calling it registration, unless you want to require submittal of copies of the title and registration.
Gene
Gene and Ben
Old 01-01-2008, 08:56 AM
Gene
Gene, yes, absolutely no problem with that, it might fill both requirements for many people.
Wording could be along the lines:
At the inception date of this current membership form member ..........[insert identity] had the following vehicle listed with the SVXWN:
Vehicle: Subaru SVX
Color: Claret and Black
Year: 1992
VIN: JCICXW1234567
Changes to these details, or else verification that they were unchanged, would have be be received from the member before a subsequent certificate was issued for the following or subsequent years.
Old 01-01-2008, 10:37 AM
I agree with the way this thread is moving. I really didn't intend for the adminstrators to incur any responsibility for anything other than furnishing information concerning the rarity of the car.
I think this thing could become a good fund-raising opportunity. The network could issue, for a fee, certificates valid for one year, based upon receipt of a copy or scan of the members current registration. The certificate would say that the member "has listed" the vehicle with the SVX World network, that the vehicle is the x,xxxth vehicle of y,yyy that were produced that year of a total 21,xxx ever produced.
On the form also ought to be some statement to the effect that the owner is a member of the SVX World Network since 2zzz.
We could set up a committee of members who would receive these requests, fill out the certificates, all but the official signatures, and then forward them to the adminstrators for signing. The committee would need whatever algorithm John used to determine the ordinal production rank of the vehicle, based on the VIN. The certificate could then be forwarded to the applicant, either in hard-copy or locked .pdf format.
If this is the way it is going, I would volunteer for the committee, since I opened this can of worms.
Old 01-01-2008, 11:06 AM
I also want to apologize for my earlier gaffe concerning the legal status of the SVX World Network. Didn't know it was a corporation; also didn't know about officers, and color coding of user names. Must have missed the post where that information was recorded. Is there a page with a listing of officers, etc? Thanks.
Old 01-01-2008, 11:22 AM
crusader8 crusader8 is offline
outsider
Send a message via AIM to crusader8
I notice there has been alot of talk about the NJ inspection and what qualifies. Have you spoken to any insurance companies because I think that would be the hardest part. I tried to gte my truck registered and inspected as a collector car and the insurance co. needed pictures of the car, proof that it will be garaged, they asked a ton of questions to make sure its not going to be raced. Then they will tell you its not a collector. best way to get around it is to not talk to the first person you call, ask for a supervisor.
1993 blk/blk GMC Typhoon. RPM built motor, PTE-60 turbo, vortec heads, RPM A/A, George Blake 4l80e, Code 59 tuned
11.80 @ 113 mph on 18lbs Boost
NEW MOTOR BEING BUILT AT reids performance Whitman Ma
I know its not an SVX, but its fast
A Typhoon is like a girlfriend - takes a lot of money to keep going, but when she puts out...
http://www.cardomain.com/ride/825685
2003 Ford Ranger EDGE
When I find the right amount of money I'll find the right SVX
Old 01-01-2008, 11:40 AM
Spoke briefly to the insurance company. Haven't done anything specific yet. SVX will be off the track and in the garage as of this year.
