Stall when put in Drive
When i got the car the alternator had gone bad and fried varistors in a few different things as well as the tcu. A friend of mine soldered new ones in, and i replaced the alternator with a higher output one and did the "Big 3".
Problem I'm facing now is when you put it in drive it stalls out completely, it will go in reverse though... I'm not sure what exactly would cause this... I did try using another TCU that i grabbed from a junk yard, but that didn't make a difference. It is possible that a component could have fried in the ECU? I did grab an ECU as well but didn't have time to switch it out, or open it up and check it out. There are also no CEL's being thrown either. Anyone know what the cause of the stalling may be? Thanks, Joe |
Re: Stall when put in Drive
i didn't have any alternator or resistor frying problems with my first pearly , i used to shift fine then one day started shifting very harsh , then stalled out at the bottom of a driveway , started again and parked and from then on it would stall in any "gear". P and N it would idle fine but when i moved it to any gear it would just grab and stall i was told it could be something inside the box or the torque converter had disintegrated internally . my dad (30yrs+)mechanic pulled it apart to see if he could find anything that would make it stall , he found nothing wrong with it at all i was then told it could possibly just be the "b" solenoid not working which im guessing controls the amount of slip the torque converter uses , in which case if its that , it wont slip at all causing the stall |
does it stall if you have all 4 wheels off the ground? you may be able to find out if it's not allowing slip (possible torque converter lockup solenoid) by shifting it into drive with your foot off the brake.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Problem is I don't have access to it everyday. I just moved from Maine to newhampshire, and left the car at a friends in Maine |
I doubt it is the torque converter as it will go in reverse. Harvey.
I hope its not the TC, obviously that is a lot more work... The over voltage was cause by the voltage regulator going bad in the old alternator. Causing it to send 17-18V out. but lets keep ignoring that haha |
