AMR Radiator install and Fitment
Ok so I received the prototype AMR Radiator today I took many many pics and showed each step in the install process. I hope you like it.
First was the un-boxing, One of the first things I noticed besides the quality of construction AN Fittings for the transmission cooler lines. I have a manual transmission so I didn't need to do anything with them but I spoke to Andy and he said the radiator will come with the AN to barb fitting, ![]() So putting the fan shroud on the drivers side went on perfectly I did run into a little issue putting the passenger side shroud on though ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 92 SVX; 04-06-2016 at 11:20 PM. |
Re: AMR Radiator install and Fitment
I wanted to get this installed and going and I have a spare passenger side shroud so I modified mine to fit.
![]() I did the wiggle/jiggle to get the feet pegs set in and it dropped in perfectly. ![]() ![]() ![]() There is lots of room between the fan shrouds and the engine for some of the more modified svx's out there ![]() the view from the underside ![]() I vacuumed out the system and it held great and refilled ![]() A couple of videos of that vac and fill, and how good it cools |
Some may notice that the top rad mounts are missing a bolt each, they are broke off, been that way since I had the car it never affected anything so I never bothered with it.
So the only problem is the fan shroud mounting points don't line up?
only the passenger side shroud, and not far off, I slotted out the tabs on the passenger side fan shroud so I could install it in the car.
Thanks for the great update.
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
You are Welcome
Just paid....if this is my last post, it's beacuse my girl friend killed me......send help.
I placed my order today.
I just checked out your videos. What type of coolant are you running?
The long life Asian formula, its red, I don't really know much more about it, it was reasonable price at the parts store.
Thread Tools | |
Display Modes | |
