Old 06-25-2009, 08:15 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
Swimming pools need some help
Ok I bought a used 18' above ground pool with a cartridge filter. I have got the pool up and running but the water is cloudy but blue (dead algae) . The cartridge filter isnt cutting it and have been tossing the idea around of using a 10 gallon container with a inlet and oulet filled with lava rock. Ive seen this done on natural ponds and seems to filter the water quite well. How do you think this would work for a swimming pool?
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 06-25-2009, 09:49 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Cool Re: Swimming pools need some help
Lava rock? Uh....forget it.
Bite a few bullets & get a Hayward 3/4 HP D.E. filter.
Ron.
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
Old 06-25-2009, 09:50 PM
y2daniel1981's Avatar
y2daniel1981 y2daniel1981 is offline
It may filter the algae, but it wont filter the bacteria. Plus you'll have to often take out and clean/scrub the lava rock or replace it. Replacing the rocks would be easier and cleaner then just trying to clean it though because the lava rock is so porous.
I'd say stick with the cartridge. Maybe get something more powerful?
You may just have to get a fresh cartridge and completely change the water a few times to get all the "left overs" out of the used system.
Old 06-26-2009, 08:36 AM
ZMan's Avatar
ZMan ZMan is offline
http://www.delozone.com/index.php?op...=99&Itemid=467
Old 06-26-2009, 09:42 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Try putting in some shock. I know my pool was cloudy for a while untill I changed the sand in the filter.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-26-2009, 01:55 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Last time I checked bacteria wasn't growing beyond the smallest filtering source DE which will filter out 2 microns. That's why you use Cl or Bromine. This coming from someone who maintains about a million gallons of pool water each day. I really dislike pools.
If the cartridge filter is sized right it should be fine. What is your free and combined cl, ph, Alk and calicum hardness at? Thse are the important things first
If your Cl isn't at least above 5.0 free Cl then your not gonna get it through the system and kill it off.
Old 06-26-2009, 08:06 PM
Well I was meaning if he just went with lava rock as his only filter method and no clor
