Adjusting Nut Size On The Rack
Anybody with a rack?
Does anyone have the steering rack out? I am looking for the size of the nut, the big hex, that gets loosened to tighten up the steering. A special wrench is need to do this and I think I can make it for less than Subaru wants to charge. Thanks John Last edited by svx_commuter; 06-06-2002 at 05:11 AM. |
This is supposed to be a standard part of the 30k maintenance
I was once on a rack. It adjusted more than the size of my.........
Larry IIII |
Someone has to have a rack somewhere to measure this. Please.
What's wrong with using 20' pipe wrench?
Oh.... STEERING racks. Sorry, I thought we somehow got off on the topic of motivational techniques in a Turkish prison.
Never mind. Ron
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Sorry - I've adjusted mine with the rack out, of the car, so I did not have the clearence problem. You could always disconnect the steering linkage and rotate the rack around it's axis to get a better access to the nut. I am not sure how far it will rotate, especially with tie rods attached, but rotation is a part of standard removal procedure...
Do you happen to remember what size the LOCKNUT was?
I would have to disconnect the hoses to rotate it. Right? Did you rebuild your rack? How is your transmission running? |
