#2731
Dyno'd the car
#2732
Actually Drove the Yellow 5-Speed over the weekend....pretty sure my Tach is reading low......any ideals what would cause that?
#2733
Did a few post painting things. Auto folding mirrors installed but not wired, installed reworked to brighter LEDs rear brake upper bar light and custom partial de-logoed center light. Next warm day hope to reinstall the rear quarter garnishes. Need to remove and dry out condensation in the rear right brake light housing.
"Peace is the flower of justice." |
#2734
photo of rear light partial de-logo.
#2735
I have done many things over the last several weeks, pulled the engine to drill out and extract 2 broken valve cover bolts found (as suspected cam timing was one tooth off, found (as not suspected) every cam cap was over torqued and 2 cap bolts broke when trying to loosen. Then the intake cam snapped and the timing belt tensioner was not reusable.......... all in all a very eventful eye opener.
So lucky for me a parts motor dropped into my hands at the perfect time and I was able to get the engine going while it was out I redid my clutch pedal set and ended up making it quite better, the pedals are low and work as they should. So after all that got it driveable and find that left rear cv axle is bent and so found a used one and am getting ready to install it. I had HIDs one ballast went bad heard good things about LED's so managed to find some cheap and put them in now every outside light is LED and it looks good. (now to find all interior lighting in led's) lmao. |
#2736
Took out my leaky radiator, and drank a Stella.
And after browsing for a while, it looks like a bugeye wrx radiator will work just fine. I just need a wrx upper hose, and maybe do something with the mounts, but dimensions are very simliar and lower hose should line right up. Cool beans. Gotta love engine design commonality. Front of EJ engine basically = front of EG engine.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! Last edited by Nevin; 03-31-2016 at 10:52 PM. |
#2737
#2738
I had the rusted rear sub frame on the '97 replaced with a pristine one from San Jose California.
I traded my '99 Sierra with a rusted out body and frame for the labour cost. |
#2739
Please post your results and photos as you go.
#2740
there is no radiator fill neck on a WRX radiator, NO radiator CAP. They have a separate coolant fill tank…….same as a 91-94 Legacy Turbo. SVX has a radiator cap at the radiator, and fill neck on the radiator. So if a radiator from a bugeye fits, you would have to add the coolant fill tank someplace too, just to ADD coolant.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
#2741
T
#2742
Something I have been wanting to do for a while, I painted the intake manifold. Originally I was going to just use a cast aluminum silver paint, but at the last minute decided to change to satin black. A bit of a quick and dirty job since I did not remove it first, but I think it came out pretty good.
#2743
Looks like a big tarantula. Best non-stock color I've seen.
#2744
Tried out a Legacy driveshaft on the 5-speed. Too long. Probably would have worked with the back half of my oem driveshaft, but I sold it. Womp womp.
God mad. Bought AMR coilovers and AMR radiator. STi wheels getting powdercoated soon for install with suspension. Taking measurements to see if a 3" one piece driveshaft will fit on the car. 2.75" one piece wouldn't balance out over 70 mph. It's only money, right?
Mark S. 1995 LSi, EPM, #1152, 197k(ish) miles, 5-speed |
#2745
Finally brought my car home! It's not fixed, in fact it is worse in some ways I think, but at least it's here after 8 or 9 months away.
I have never seen so much bird crap.
