Old 09-21-2007, 10:14 PM
Louis,
The wiper supply circuit involves a remote relay, as well as an internal limit park switch.
Before deciding that the rear wiper is faulty, check for full voltage at the motor four pin connector with everything switched on. Check for voltage between pin 3, (black conductor to ground) and pin 2 ( blue /white conductor, 12 volt supply). The pins are diagonally opposite within the connector.
N.B. Use a trouble light or something else which drawers reasonable current, rather than a volt meter as this may not show up a resistance in the supply circuit.
Best of luck, Trevor.
