Old 09-01-2007, 06:11 AM
Bailey's Avatar
Bailey Bailey is offline
trouble finding high octane
Hi,
I haven't posted in a while! I haven't been able to find high octane fuel around here lately. Seems the octane is getting lower and lower at all the regular gas stations I stop at. I was having to use 91 but this past week I was on empty and all I could find was 89. I pumped a very very small amt in but now will be trying to find higher octane somewhere. Obviously, we have a lot of ethanol around here. (iowa) I think I will have to start calling gas stations all over town to see where I can gas up!
Old 09-01-2007, 07:01 AM
SVX_MY_BABY's Avatar
91 is the highest offered here. Works fine. I'm pretty sure you can use up to a 15% ethanol mix in the SVX. The info is in the user manual.
Perhaps you should get a couple of cans of octane boost from the hardware store.
Old 09-01-2007, 08:41 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Lower
I've burned 86 in mine for 12 years and all of them for a number of years with not a single problem. The one I have had the longest now has well over 200K miles.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 09-01-2007, 11:36 AM
JaySVX's Avatar
JaySVX JaySVX is offline
one bottle of that "octane booster" will put you up about 1/2 octane. Simply put, it's extremely overpriced and overrated. Bummer about only being able to find 89 octane, i've never heard of places not having 91 or 93 at least. I normally go to sunoco, which has 94 for the same price as every other places 91 octane. Hopefully some will turn up soon.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-02-2007, 06:38 AM
You should read this Technical Service Bulletin.
http://svx-iw.com/svxiw/article/?article=30
Old 09-02-2007, 07:58 AM
lhopp77's Avatar
Key Point
Key point to notice in that TB is that the "ECU will learn to run on regular fuel". It does that very effectively and runs with no ping or adverse noises of any kind. There is also no noticeable loss of power and fuel economy is the same as with premium. My over 200K mile car still does not use any oil between changes and the oil still looks very clean.
I have just saved myself pile of money over the years without hurting the engine.
Having said all of that--it is still your choice and IF you engine pings or makes any strange noises I would immediately go back to premium. Octane booster is a very expensive way to obtain higher octane fuel.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 09-02-2007, 01:46 PM
Hondasucks's Avatar
Subaru Technician
Do you live at high altitude? When I lived in Laramie, Wyoming (Elevation 7200') we had 85, 87, and 89 octane gas.. Down here at sea level, we have 87, 89, and 91... I guess at high altitude due to the thinner air, you need less octane to keep it from pinging...
I've also found that some places drop the octane in the winter, something about heat making things ping... My friend used to have a 91 325i and he said it pinged real bad in the summer even on premium but he could run plus with no problems in the winter.
1986 VW Jetta
Old 09-04-2007, 05:43 AM
dcarrb dcarrb is offline
The Subaru line is (or used to be) up to 10% ethanol/NO methanol. Consider this before using "E85."
You don't need a chip, you don't need octane booster, you don't need racing fuel. My cars have never had a steady diet of premium. Not since I've owned 'em, anyway.
dcb
Old 09-04-2007, 06:11 AM
Bailey's Avatar
It is good to know it won't kill my car if I have to put in 89 octane then. I will still try to track down at least some 91.
Old 09-04-2007, 06:56 AM
crazyhorse's Avatar
242,000 mi on oem trans
There's a Sunoco here in redneck land that sells 110 octane. Just for giggles I've run it in my Pinto, I was able to bump the boost & timing WAY up
Of course shortly thereafter, I was pulling the Turbo motor out & reinstalling the stocker. Too much boost, not enough fuel.....oops
"42"
Current Stable By Age:
Old 09-04-2007, 08:00 AM
Evil One Evil One is offline
Pinto Boosting Freak
Send a message via AIM to Evil One Send a message via MSN to Evil One Send a message via Yahoo to Evil One
On 110-114 I was running 17 degrees and 28 psi
Jim
Old 09-03-2007, 03:08 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
Contact LAN at ECUTune. He can set you up with a setup that will allow you to run E85, or you can buy one of his stage one sets that will allow you to run regular gas. He's the one doing the supercharger kits and engine parts in the Mods forum. He goes by Longassname.
Old 09-03-2007, 04:35 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
get a few barrels of 115 race fuel shipped to you and mix a few gallons of it with regular pump gas whenever you fill up.
Old 09-03-2007, 05:45 PM
Wikedjuggalo's Avatar
Rebuilding
Well here in fayetteville, I get 91 no problem and 93 but sometimes at Exxon or something I can get 94 >.> !
