Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #196
Old 04-06-2007, 01:34 PM
longassname's Avatar
Just some dude.
I ordered the valves today.
Old 04-06-2007, 04:47 PM
sicksubie's Avatar
uhmmm... Was I included?? I can call and pay you at any time.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 04-06-2007, 05:09 PM
Just some dude.
305-546-9359
Old 04-09-2007, 08:28 AM
cdigerlando cdigerlando is offline
Payment
Just sent you a payment. Hope I'm not too late.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 04-09-2007, 11:30 AM
Just some dude.
you're in on it
Old 04-09-2007, 11:43 AM
I'm in!
Great. I'll try to get on removing the cams here soon. Let me know when you can't wait any longer, and I'll try to get them out without removing the motor.
Chuck D.
Old 04-09-2007, 11:50 AM
Just some dude.
and looky what I got today. Here are some pictures of the first set of cams ground...the prototypes if you will. Sorry, not cleaning off the packing grease for pictures--deal with it.
complete set of boxed cams
intake cams
Here's a picture of the base circle of the 1st lobe on the intake cam. This is where the camshaft is thickest. What I'm trying to show in this picture is how the base circle on our cams does not cut into the shaft. This illustrates how our valve set up maximizes lift before coil bind without degrading the strength of the cams.
close up of intake lobes illustrating fillets (radius in castings up to sides of lobes) not cut into.
exhaust cams
exhaust cam 1st lobe showing shaft is not cut into
close up of exhaust lobes illustrating fillets not cut into
So there you go...good, clean, exactly right performance cams with state of the art profiles.
Old 04-09-2007, 12:02 PM
Pictures!
Awesome. Thanks for the pix. It will be great to see how these perform for you. It will also be very interesting to see improvements for the N/A guys as well.
Chuck D.
Old 04-09-2007, 12:27 PM
Just some dude.
I won't be putting my cams in until I have the rest of the parts to build my engine which will be very far from naturally aspirated. The only NA guy to order the cams so far is OBI who is also changing pistons and who's engine is in a porsche.
Old 04-09-2007, 01:24 PM
sicksubie's Avatar
What???? I am shocked
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 04-11-2007, 03:09 PM
Compression ratio
The compression ratio on the pistons is 8.5:1? It will be interesting to see if OBI has any performance drop due to the drop in compression. We had a fellow online some time ago from england who said he dropped to 8.5:1 and had no noticeable drop in power. Then again he didn't dyno.
Chuck D.
Old 04-11-2007, 10:56 PM
are we going as low as 8.5:1??? I thought it was going to end up closer to 9... lower is better for more boost Mike... have any idea where our rods and pistons are?? I would love to get my bottom end put together so the people who want me to build theirs can get their costs figured out
Old 04-12-2007, 08:07 AM
sicksubie's Avatar
Yes, indeed.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 04-12-2007, 11:25 AM
OBI OBI is offline
Talking
Im using the pistons so that when i get tired of running n/a ill go turbo. its gonna be a while. I think running n/a using mikes cams ill probably have traction problems.
EG33 Turbo Porsche 914
Old 04-12-2007, 06:44 PM
Just some dude.
I'll call and check.
