crazy starter problem
My 92 5sp has some strange starter problem. It first occured last year when I put in a reman '97 outback starter. The starter worked fine for a week and then the key wouldn't start it anymore unless someone was tapping the starter at the same time. So I got another starter and the problem went away. But it recently started acting up again and I replaced the starter for the 3rd time only to find that starter has the same intermitent problem. The wire from the key is putting out 8.5v in the start position always but sometimes the starter doesn't respond at which point I have to get out and jumper a wire from the positive battery terminal to the ignition input on the starter, then the starter jumps to life. Does anyone have an idea as to what the problem may be?
Thanks, Chris |
Two possibilities come to mind:
The ignition switch on the SVX has a tendency to work its way loose. Removing the cowling on the column and make sure the security bolts are tight and not letting the switch come away from its "seat." If that's the problem, you'll either need to remove the original security bolts and replace them with standard, or, order some new knock-off bolts from subaruparts.com. My intermittent problem was much simpler than I had ever anticipated. After fiddling with the starter, checking relays, checking ignition switch, replacing battery terminals . . . etc, I discovered the terminals weren't on tight enough. Though they "seemed" tight, they just didn't quite make the right connection. Seems silly, I know, but, I haven't had a bit of trouble since I pulled the terminals, cleaned the posts and terminals, tightened them sufficiently and spread the posts and terminals with a layer of petroleum jelly (to prevent corrosion).
I am having the ( EXACT ) same problem as you Chris. Right after doing the swap, my starter started acting up. The really anoying thing is that you still have power at the starter wire and if you jump the starter terminals the motor will spin over, so you put the wire back on and try it again, nothing
I thought I had traced it down to the relay for the security system( it's a Boch relay mounted to the side of the steering colume). I measured the voltage at the wire whe nit wouldn't work and I had 9.00V, so I figured I had a voltage drop in the relay so I put a jumper wire across the two terminals and it worked fine. I later got the same relay from NAPA and reinstalled, everything worked fine for awile, and then it started acting up again. So I put my jumper back in and it work for a little wile longer but then it started acting up again. Now it seems to never start when I first go out in the morning, and the really, really anoying part is that unless you have a long jumper wire, you need to have someone hold the key to the start position wile you jump the starter terminals under the hood. So, no I haven't figured it out yet but my next move was to get another starter But just so you know your not alone.
If anyone is looking for the internals from a starter let me know. I had to replace mine as the core was cracked where the bolt hole is and it wasn't secured to the car. The starter is about 1 yr old.
Keith |
hehe, I'm still mid-conversion but my starter is having similar problems. It will click when I turn the key with the clutch down. I was only able to properly engage the starter twice. The starter needed a solenoid before it was installed but this problem is with the new solenoid.
Also the ignition is not giving me back my key (can't turn into lock position) now. I've already jumped the outside pins on the 4 pin connector by the shifter.
has anyone ever figured out the solution to this problem?
Yup!
I bypassed the security relay and used it at the starter in order to supply 12v from the battery when the switch is in the 'start' position. I don't know where the voltage drop is but it only took five minutes to wire the relay at the starter and now it's never a problem.
So Beav did you just run the Blue-white wire right to the starter along with the black-yellow wires? I plan on changing the wireing on mine when I redo the pedals so if you got the goods let me know. I don't know why or where the voltage drop is but it's really annoying.
Typical Bosch relay - (why can't I ever remember the term. numbers? Oh well, at least there's a diagram on the side of the relay.) Battery in, original solenoid trigger to relay trigger, battery out to solenoid, add a ground to chassis. Supplies battery voltage directly to solenoid - problem gone. Tuck relay above solenoid.
Had thought of that to but didn't want to have to worry about bad realys again. But if it works I'll get it hooked up.
Re: Yup!
Re: Re: Yup!
Pics? How-to?
help!
I could use some pics or additional explanation as well. I just got my starter rebuilt and the same click, no start thing is still happening...
P.S. 200 posts! Eat my dust!
Front to back, sorta: Claret 1992 Subaru SVX LS-L, JDM STi open front diff six speed, STi tranny mount, Kartboy shift bushings, WRX CD changer, rear R180, battery in trunk, Stebro exhaust. 2000 Specialized RockHopper A1 FS, converted to singlespeed 36:15. I like my cars with too many gears and my bikes with too few... |
-Like this Beav ??
/Sonny
Internal name: "SuperSonic" -92 ebony black with 170k KM *** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. *** |
