Old 03-08-2021, 11:01 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Rear window wiper interior shroud.
Does anyone have a spare tan interior rear window wiper shroud? The shroud on my '95 Brilliant Red is much the worse for wear.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 03-08-2021, 01:30 PM
irox irox is offline
Re: Rear window wiper interior shroud.
Mine is looking in similar condition... but grey and falling to bits.
At some point I'll take my rear shelf off, install some new speakers and fix up the carpet/cover. I might take a shot a designing a replacement, but would have to figure out some heat resistant plastic to make it in, I'm sure PLA would quickly deform as it's hot on that shelf. Possible shapeways could print one in nylon, which could painted to match the interior.
Good luck, let me know if you find a grey one.
Cheers,
Ian.
Old 03-08-2021, 01:33 PM
Will do, although it's been suggested that I get one of whatever color and paint it. If that works, you can have the second one I find.
Old 03-08-2021, 04:13 PM
If it helps, the Beige one is part number: 86538PA000DO
And the grey one is: 86538PA000VG
Subarupartsdeals.com might have a Beige one in stock:
https://www.subarupartsdeal.com/part...38pa000do.html
(They don't have any of the grey ones for sale, so many be you are in luck)
Cheers,
Ian.
Old 03-09-2021, 03:22 AM
On mine the release levers and covers for folding the back seat down are looking nasty. Faded and beginning to crack.
Nearly all rear seat parts are discontinued including these.
Old 03-09-2021, 01:10 PM
Ordered from Subaruparts. Thanks irox
Old 03-09-2021, 01:33 PM
Was just notified that order was canceled because item was unavailable.
Old 03-09-2021, 02:36 PM
Ah, sorry they are out, I had that with something else from them recently as well...
jauce.com might have them occasionally.
