svx dies after running for a few mins what to try?
hi im having a problem with my 94 svx as its shutting off after a few mins running when i have changed alternators,changed in 5 diff maf sensors,along with a few other parts over the last 2 days.it will die but start back up with no problems until it starts running real choppy and then quits.i have discussed this problem with svxess aka john who has taken alot of time to try to help me with this problem.any suggestions of what i should replace tommorow. ihave a complete parts car to take parts off. thanks josh
Re: svx dies after running for a few mins what to try?
Try the crank and cam sensors next.... heat makes the magnetic tips lose functionality... so if they are weak already.....
The FSM troubleshooting charts suggests the cam sensor if the car starts and then stalls (but doesn't say if the stall is immediate) I thought a bad crank sensor would keep the car from starting at all. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-03-2010 at 09:29 PM. |
I would agree that it sounds like the position sensors. Swap the three of them see how it is then.
ok so ill replace the cam sensor and crank sensor tommorow morning so i can rule out those or possibly fix my problem i hope.this svx has never given me a problem so it figures it happens right before reading meet.anything else i should try to change tommorow? i need to get my svx fixed asap so any suggestions would be nice.thanks
The correct procedure is to swap one at a time. Then you will know which one of three is faulty. Otherwise you will wind up with three sensors all, suspect and useless.
what are the 3 sensors?cam,crank and what other sensor?forgot to write no check engine light so i dont know exactly where to go if these sensors dont help.thanks guys
