symptom help request
Hey all,
So I had a low mileage used tranny installed about two months ago when the original died. It's been driving and shifting fine until recently, when i've noticed on three different occasions, about a week apart, that it slipped shifting from 2nd to 3rd (revs briefly before shifting)(while in 3). I drive in 3 when the posted speed limit is below 40. Again, it doesn't happen regularly, just once, and on 3 separate occasions. I've got a 6 month warranty on the tranny and I need to know if I should go back and get my money back. Four months to go! Thanks! |
Re: symptom help request
Sounds like the brake band is starting to wear and needs to be adjusted asap to prevent it from getting worse and wearing out the high gear clutch.
Slight chance that it could be the tps but I would bet on the brake band. Last edited by 1986nate; 03-19-2009 at 01:08 PM. |
Thanks Nate! There is a good transmission shop here so i'll see if they can do it.
also, should i avoid driving in 3 until it gets adjusted? Going to get it done tomorrow but just curious - is the brake band what provides engine braking? Last edited by oregondave; 03-19-2009 at 01:55 PM. Reason: forgot something |
Out of curiousity - what exactly does the brake band do? I have to say i'm amazed with the incredible technical knowledge you guys have. This site is a godsend. |
For third gear the band is released, and the high clutch is applied at the same time. If the band is loose, it releases before the high clutch has come on, so the box goes back to first, till the high clutch clamps up. Nothing is slipping when this happens, it is just a matter of timing, but it can start the band slipping when in 4th gear that will burn it out. That's why it is important to do the adjustment early. Harvey.
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by oab_au; 03-19-2009 at 05:06 PM. |
