Is the stealership taking me for a ride with the big hammer?!
So I figured it's time to get my crank shaft pulley replaced because I didn't feel very safe with is slightly wobboling the way it was. Took it to Martin Subaru down in Sicklerville, NJ and they looked at it today.
They told me that I needed a new crankshaft pulley (obviously) and that the one that was originally on my car isn't for an SVX. Is that even possible? They said with the different pulley that was on there it might have done engine damage. Kind of weird, but the engine runs fine - pulley just wobbles. so they also told me that the lugnuts I had on my wheels aren't the correct kind.........(whatever that means) and that they aren't really holding the wheels on the car. New lug nuts are like $8 a piece ....jez Dam SVX ....I just hope theres no engine damage There getting back to me tomorrow Crankshaft pulley, lugnuts, labor = $644!!!!! WTF
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Picture is worth a thousand words
If you post a picture of your lug nuts and the pulley... there are enough of us here that have dealt with them... we might recognize the problem if there is one.
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
Re: Is the stealership taking me for a ride with the big hammer?!
I needed a different type of lugnut for the new wheels on the Justy. I paid about $20 for 16 of 'em. $8 apiece is nothing short of the aforementioned plunger rapage. I think they used the handle end.
$644 to replace the lug nuts and pulley is criminal. Edit: I just checked Subaruparts.com and they list the pulley for $148. Even if a dealer charged you $250, it shouldn't take more than an hour to replace. $250 for the pulley, $160 for the lug nuts ( ) and two hours of labor at $70/hr I still don't hit $644, but maybe with tax...
2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE Last edited by Mr. Pockets; 03-31-2004 at 03:59 PM. |
Subaruparts.com shows $5.30 per lug nut so $8 for list is probably right. They show list on the pulley at $194.40 & sale price less than $150. If the pulley is already hosed, then getting it off is no big deal (normally one has to worry about pulling it apart). I would guess the official labor to be about an hour for lugnuts and pulley since I could do it in that time. That means $290 in labor. I hope they plan to give you a kiss while they do this to you. |
$5.30 per lug nut is ridiculous but probably reflects their costs in distributing the things. I would think that, instead of applying the same equation to every little part, on some where the cost didn't make sense they'd eat a little to make people happy.
$290 for labor on those services is nuts. I would demand to see the book rate on that one.
There are probably lots of SVX's running with the wrong lug nuts (though they shouldn't be). SVX lug nuts have a much wider flange than normal at the base of the nut to evenly disperse the torque against the factory aluminum wheels. The dealership is correct in pointing out that incorrect lug nuts don't work right- broken lugs, warped rotors, bent wheels, etc., not to mention the possiblity of the "Wheel-less belly slide".
They are also correct in pointing out that an incorrect pulley could potentially cause damage. Having said that, they are hosing you. With a fire hose. As you said, the motor runs fine. The pulley thing is just a scare tactic. And the price makes many criminal acts look kind. Get your car out of there. And spread the word on this particular dealership through this forum and others. Any shade tree mechanic can handle the pulley job (even I just did one!). You could probably get used lug nuts on this forum- I did. NOTE: It is possible the existing lug nuts were the wrong thread pattern and forced on with an impact wrench. If so, you'll need new lugs, like I did. Again, any average mechanic can handle this. Good Luck!!
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!! '92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC |
Yeah I really don't feel too kind with the price quote they gave me. I'm going to ask them exactly what their labor rate/hours were for the work being done. I think the price is just out of hand.
The reason why I kind of like this dealership was because they are pointing out stupid things that are wrong. Like lugnuts ........if they look at that stuff wouldn't you believe that they kinda "know" what they're doing with the SVX? ORRRRRRRR - are all subaru lug nuts the same where it's not particular to the svx? i hate dealerships ....... [sorry i just had to] No, you didn't have to - Todd
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash Last edited by wawazat??; 04-01-2004 at 04:28 AM. |
Rmj, where in NJ are you located? I have had the pulley off to do a timing belt/water pump change and it is not difficult at all. All you would need is a 10mm rachet, new pulley, a breaker bar, a 22m 6pt socket, a torque wrench, and a large flat head screwdriver. The rachet is to take the radiator fans off and the ac and ps belts, the screwdriver is to hold the flywheel as you crack the bolt, the breaker bar and socker is to take the pulley off, the torque wrench is to put it back on. I'd be happy to help you out. Lug nets are even easier
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
Ask them why they're charging you $290 in labor as you hold up the lug nuts you bought for $20 from a few parts cars.
P.S. Using parts from totaled SVX's is like human organ donation. Everytime it happens an angel gets its wings.
-Craig Lowthorp, Flagstaff AZ '92 LS-L, Black on White, 136k SOLD '92 LS-L, Black on Silver, 120k SOLD '01 Legacy Outback, White, |
MJJensen,
Contact 'SVXROO' (Ken B.)privately. He lives down by you in south Jersey. He owns 2 SVXes besides Lotuses. He's a good guy and a terrific mechanic. He does not use Martin. Talk to him. Good Luck.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
timing belt also?
Are you sure that the quote doesn't include a timing belt? That total seems consistant for a pulley, timing belt, lug nuts, and labor.
You have to keep in mind that the SVX is different from every other Subaru. 99% of its parts are not shared with anything else. So, yes, the lugnuts are different. As far as the pulley goes someone probably tried to save some money and put a Legacy pulley on there. Is it different from an SVX pulley? You bet. The SVX's individuality is what we all love......but it's what we all hate too. Parts are different, more expensive, and not as plentiful as other Subarus. Driving a nice car comes at a not so nice price sometimes. If you do decide to do the pulley yourself, make sure you torque the bolt to the correct value. In the last month alone two of my customers had to replace their engine blocks after they changed there own crank pulleys and did not torque the bolt to the correct value. The wobbling pulley was enough to damage the pistons. Dave |
Acctually Dave I belive the wobbling pully wrecks the end of the crank. This was the reson I had to change the motor in my freinds Imprezza.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
You are correct sir! It was their crankshafts that were ruined, not the pistons. I stand corrected. Dave |
