Old 11-29-2013, 12:44 AM
danielparker danielparker is offline
How are European License Plates Mounted?
Hi,
How are European License Plates Mounted on the front bumper?
Is there a 'long' version of the plate 'tag' mount for Euro versions?
Here in New Zealand, we have plates that don't fit properly on the JDM mount.. If there was a Euro mount, I could get a Euro sized plate to fit.
I cant tell from the photos that i have found, hence the question.
Regards
Daniel Parker
Old 11-29-2013, 03:06 AM
Tapani Tapani is offline
Re: How are European License Plates Mounted?
See photos here:
http://www.nettiauto.com/subaru/svx/5639142
/T
Old 11-29-2013, 01:41 PM
OK.. It looks like there is a European plate mount.. Now I need to find one :-)
Daniel
Old 11-29-2013, 03:31 PM
You can find the universal european license plate frames easily online at amazon.com and ebay.
Also at EUROPEANPLATES.COM and LICENSEPLATES.TV
Old 11-30-2013, 01:12 AM
ShaneHobson ShaneHobson is offline
I took the JDM license mount off and fitted the NZ plate directly to the bumper.
My NZ car has the same JDM plate mount as my JDM.
Old 11-30-2013, 03:13 AM
Yes.. my NZ Plate is mounted directly onto my bumper (badly). I plan on getting the Euro mount and Euro plates.
Old 11-30-2013, 03:15 AM
Its not the frames, but the actual front mount that I am interested in.
Old 11-30-2013, 08:25 AM
That will probably be an OEM part. I have successfully bought european-spec SVX parts from Bell & Colvill in the UK and they ship internationally. The German SVX's use the same Euro mount as the UK
http://www.bellandcolvill.com/parts/subaru.asp
Old 12-02-2013, 10:14 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Daniel,
did you check out mine - because it was on an earlier car (Honda Civic Turbo, with skirts all around) - I had to cut it down to fit into the recess area at the rear - using a mill to get sides square with top/bottom..
That plate is now at the front of the SVX - and it is the same size as the mounting plate.
