Wood stove link
Since my shack is over 155 years old and it would cost $500. per month to heat it with gas or electricity, I have chosen to use 'renewable' resources for heat.
I have tried a lot of different 'devices' to accomplish this goal. It all started with a 'Ben Franklin' stove. You get warmer from cutting and carry-ing wood to feed it, than any heat that will actually be produced BY it! I had a 'Quality' cook stove for a while, but it only heated a room or two. I bought a 'Warm Mourning' stove. It wasn't too bad, but I traded it ' Heat-o-lator' that worked better, but still fell short of my expectations. I kept falling back on an old Montgomery Ward 'heatrolla' between experiments. The wife found a deal on a Waterford parlor stove. we tried it. Does anyone need a 'real deal' on a 'yuppie wood stove'?? Yea, It was pretty........ A guy that works at the crusher called one day. Someone had scrapped a 1942 Pick Oak pot bellied stove! I ran over and paid him his $75.00 and threw it into the GMC. I installed it the other day and fired it up tonight. I put 6 pieces of 'kindling' and some junk mail in it. It was 92 degrees!!! We had to open 3 windows and put a fan in the room to get the temp to a comfortable level! I think I found a 'match'. Of all the stoves I have tried, this is the first one that actually DID what I expected! A 1942 model! I have only been working on this for 20 years now. This thread is for wood stove guys to help other woodstove guys keep warm
I'm not a REDNECK! I am an Appalachian-AMERICAN!! "Can't go to work today. The 'voices' said to "Stay home and clean the guns". Most famous Red-Neck last words... " Hey Everybody, Watch This!!) http://s306.photobucket.com/albums/nn272/subi-crosser/ Jerry |
I've been toying with trying to build a waste oil furnace to heat the garage at my house. I have a fireplace inside the house but I don't use it all that much since it doesn't do the greatest job at heating the house, I think it's more for decoration. I'd replace it with a wood stove but the way the room is laid out, it'd suck with a wood stove in it, unless it was a long thin one that was as wide as the fireplace but didn't stick out from the wall more than a foot or two. I know I could put an insert in there but #1 those are expensive and #2 I'm not convinced it'd heat any better than the fireplace...
If you can weld, you can build an insert. Most store bought inserts have a fan that pushes the heat out where you can enjoy it. Fireplaces,' as originally designed' are pretty, but serve no purpouse other than that.
I've got a couple of questions. I've got an old (not sure how old) wood insert that has a fan and cooks me out of the house when I use it.
Can you get quieter fans for them? Mine sounds like a tank. How can you set it up so that is burns slow over night? I close the bottom dampers and the flue but the fire is still out or just about out by morning. Someone talked about 'banking' the fire. What does that mean? I put a flatscreen tv over the fireplace this summer. Nice :-) Should I go out and buy a thermometer and put it where the tv is to determine if it's too hot? And what would be too hot? Should I pull the thing out yearly to clean? It weighs a ton and it doesn't look like an easy job. I've been using it for 10 years now and haven't pulled it out yet. I do stick my hand up through the flue damper and feel around to see if it's dirty but haven't found much debris. I clean my chimney twice a year but have yet to see any real accumulation of soot there even though I burn just about any kind of wood that I can get my hands on. Has anybody got a cheap wood splitter that they want to get rid of? My wife and I use the fireplace a lot. We keep the house at about 85 all winter long and my elec bill usually tops out at about $120 around Christmas time because the wife likes to cook a gazillion pies. I told her that we'll burn until we run out of free wood and then we'll switch to gas. I'm on an acre lot with a ton of trees. Ten years later and I still have more trees than I know what to do with and I've prob got about 4 cords of wood split and stacked and another 2 cords waiting to be split. I have access to 6 large dropped oak trees but don't have anywhere to store them. The wife is ready to switch over to gas because she's tired of the mess from carrying the wood in and the dust from carrying out the ashes. But I still like the price. |
EVen if it's not free wood from your own land, I always see stuff on craigslist "I want this tree gone, come chop it up and haul it off" etc..
I don't know what wood is nowadays but I remember about 12 years ago my dad used to go to the wood lot and get a cord of oak for $150 or so and that'd last us at least 1 winter, although he'd usually go get a cord or two of pine from our friends house (they pretty much lost a tree every year) and we'd burn that during the day and then toss in some oak at night and turn the damper down and there'd still be coals in the morning... I need to find one of those fan-forced inserts.. I had a "fireplace heat extractor" but it didn't fit my fireplace so I scrapped it...
The most I paid for 'back up' heat was $135. for each of the coldest months. It wouldn't have been that bad if the wood I stacked when I went to work actually got INSIDE the stove while I was gone. As far as the fan goes, you might be able to mount it on rubber washers and make it quieter
Is there a damper on the top that you can throttle back? Of not, can you put one on it? A slower burn will make the wood last longer but if you burn it too slow, it causes build up inside your pipes/flew and increases your chance of fire. A hotter fire keeps your flew cleaner, since the tars are consumed.
Your neighbor pays $200+ per month for three rooms??? What, are the rooms like 80x80 with no insulation and just holes in the wall for windows? My FP is in the center of the house so it heats the whole house (if I leave the bedroom doors open) and I usually have to open a few windows to cool the place down. |
