Old 07-19-2006, 09:16 AM
Antigenus's Avatar
Antigenus Antigenus is offline
Send a message via AIM to Antigenus
Help - Odd noise
I have an issue with my car that may or may not be anything. When I turn my ignition to accessory everything works fine, but my engine area makes this odd sounding click. The best way to describe it like a constant bug zap from a bug lamp. It seems to be coming from the general area of where ABS pump or whatever that is, is located. My ABS light is on, and my radiator is bad, and im replacing the whole thing, and the siezed fans. Any suggestions or is this normal? I dont think i ever noticed this before.
Matt - Akron, OH
And then what???
Old 07-19-2006, 10:11 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
My power steering pump makes that sound. And, the power steering pump is in the general vicinity of the ABS thingy. With mine, if I start the car with the hood open, I can hear it. Then if I turn the steering wheel at all, it goes away. I'm not sure if this is an indication of a bad PS pump, but I'm really not worried about it (and no, it's not my o-ring. I recently replaced that with OEM).
Old 07-19-2006, 02:59 PM
Manarius's Avatar
Manarius Manarius is offline
Does this happen when the engine is running, or just in the on position? It's probably just an ignition coil priming. They tend to sound like that when the car is just in the on position and not running.
-Jason
-Obi Wan Kenobi
Old 07-19-2006, 05:44 PM
SVX10's Avatar
Oh, yea...guess you never said the engine was running. LOL.
But, my car does that also. I have no idea what it is, but I'm not at all worried about it.
Old 07-19-2006, 06:04 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
yea my car makes weird sounds similar to that too... when the engine is running it sounds like pistins moving up and down... and valves opening and closing and and when i am moving i hear the sound of tires rotating.... its normal start up noises
- John
Old 07-21-2006, 12:59 PM
Antigenus's Avatar
ok
thanks guys, i think it was something with the power steering, today it didnt make that noise. this problem was with the engine OFF and on accessory.
Matt - Akron, OH
And then what???
Old 07-23-2006, 10:31 PM
dmnknightomega6 dmnknightomega6 is offline
i had a ticking but it was alifter... couldit be your security module?
