Tach not working...
I started driving the car yesterday and have a two issues.. One: My tach is not working and two: neither blinker works (bulbs are fine)... I traced the wiring back for the blinkers and there appears to be no problem...
Re: Tach not working...
1 - Very top left 15 - Very bottom left 27, 28 - Left bank of 5 blade fuses, bottom two. The fuse circuit listings and whats actually shown in the diagrams are pretty incohesive, so I just listed all 4 possibilities I saw. Hope this helps! |
Flasher relay?
1992 Liquid Silver/Black LSL LeveL10 Stage 3 Trans and associated stuff |
I repainted the engine bay when I repainted the car and am wondering if there is a bad ground to both the tach and the blinkers... I know the positives for the blinkers are good as I have tapped them for the bulbs in my gauge pod....
I would think they ground inside the cabin, not the engine bay. You can recheck the block/chassis and battery/chassis grounds, but if those were bad I would suspect there would be a lot more not working. Have you checked the fuses? Especially since you tapped the blinker circuit to run other stuff...
hi since your tachs signal is created by the ecm and fed through connector b41 /i3 and subaru electricail connectors have been known just to come un done partly or completly with no one touching them ,and since tach and signals go through these connectors id look there, b41 is a 21 pin blue connector located in the lower part or the A pillar ,i hope this helps
