Need to find Manifold to Exhaust pipe Gasket
I just had the SVX in the shop to take care of some front end stuff, and an exhaust leak, the mehanic said the leak is from where the manifold meets the pipe and they are o ring type gaskets. He said that they are svx only parts, he may be able to fabricate if I have no luck with finding what im looking for. Does anyone know the gasket that I need and where I could find it. Thanks : )
-92 Ebony LSL, complete with all the problems -New self paint job; charcol metallic silver -4.44 tranny, Nicknamed the SexVX : ) |
Re: Need to find Manifold to Exhaust pipe Gasket
part #44022AA200 Gasket $6.50 |
Thanks Nate...cant wait to get this car quiet again
Having just finished my 5spd swap I just replaced these...
Be SURE to dig the old ones out a small flat-head. The usually get stuck on the manifold side. They're not so much as O-Ring as a Crush Gasket... Its like a circular piece of metal with a slit in it, as you tighten down the nuts to the studs on the manifold it "crushes" and molds to create an adequate seal. Be sure to tighten them enough, or you'll be in to replace them again a few hundred miles.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
