Nooooo vibration in the Rotors
It's been only about a year and 15,000 miles since I've put on my slotted and dimple drilled rotors.
Right now I'm getting a really bad vibration so I'm coming to the conclusion that I warped my rotors. I dont think I bedded the pads properly. Also after long drives often I would let the car sit a few minutes and wash the car. I'm assuming the hot brakes + cold water weren't too good for it. Any chance that getting new pads and bedding them properly will solve this?
Did you torque the lug nuts so that they have even pressure? I would doubt that washing the car would have made them warp. I would look at the brake pads or how the calipers are working.
I pretty much re-did the whole brake system: remanufactured calipers, rotors, lines and pads all the way around.
Lugs are torqued to 90 ft lbs. Fluid was just bled again. It would stink to have to replace the rotors... they still look relatively new!
Also, they should be hand tightened in the air first, then the car lowered, and finish tightened in the same sequence. If you are hauling it up hard from high speed, you might well have warped them again, likely the front if anything. If there is a way you can get the car jacked up, spinning the wheels with a friend to help will show which rotor is warped. Spin the wheel, apply the brake very easy, and if it is warped, it will possibly catch and let go once or twice on every turn. If it's pulling even, the rotors are not warped. Now if you find doing this that one or more of your rotors have warped, and if they look nearly new as you say, then you should consider having the rotor "shaved" dynamically at a machine shop. I got that done very cheaply for mine and it was a success. Joe
Or if you have been braking lightly for some time deposits can build up (depending on brand of pads). Try a couple of hard stops, works sometimes.
1999 Audi A8. No more SVX's for now. |
Hmmm, I recently had the tires changed a few months ago but I re-torqued them myself.
I thought you couldn't get slotted/dimple driled rotors resurfaced? I will try getting the car up in the air and test it by spinning the tires
I know it's been said before, but it really is important to torque those nuts up properly - sounds like you're already doing that though. I go to 75, and even that is pretty hard when undoing them with a lug nut cross-bar. Do the rotors have pad imprints on them? If so you might be out of luck. It is possible to straighten the rotors out and get rid of the wobble - I've done it myself, just by heating them up gradually to HOT and then cooling down gradually. Do what Trevor said and check the rotor/hub mating surface, you may find a bit of corrosion or something. One thing definitely worth trying (already mentioned I think) is with new pads: Check all the nut torques. Make sure the calipers are sliding properly on the pins. Then go driving - Start doing braking stops from about 60 mph to about 10mph (Don't stop completely). Increase the severity slowly until you are just above the abs level. Things should be a little bit smelly and HOT about now. Then keep driving doing some gentle stops so that everything cools down slowly. When you've cooled everything down you can stop completely. You'll know by then if it has worked or not anyway. Re torque all the nuts. Matt
'92 JDM (E) Burgandy/Black 100Km Just Crusin' |
Well I got all my done a shop and it was not doing that till about ending of last year. Like it sounds like a tapping sound. Or it would be like if I had cards in a ridding bike wheel. That is what people said it sounds like. Anyone know what that may be?
CrazyPolo95
If you have drilled/slotted rotors this sound is completely normal. All it is is the sound of the air moving through the holes. When you hit the brakes it restricts air flow when each hole it sliding between the pads and when they open to the air again it is alowed to flow back through...So it is absolutely NOTHING wrong with your brakes |
