Old 11-18-2011, 06:09 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Where is a good place near driver's seat to ground?
i want to install power mode mod over my thanksgiving break, and i need a good spot to ground that lonely pin #4. i already tried it by switching pin #6 with #4 so i could control it via the manual mode button. it worked well, but i missed manual mode, especially in traffic. i've seen the posts on grounding it to that blue wire by the kick panel, but i feel like i'll break something by slicing wires, or slice the wrong one... so, other than the door, are there any other places i could use for ground (without removing the whole radio cage)? i thought about the parking brake handle, but wasn't sure.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-18-2011, 06:24 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Where is a good place near driver's seat to ground?
Your putting a switch near the center console??
- Any of the screws holding the shifter base to the tunnel.
- Bolts holding the ebrake handle down
Or put a DPST stitch between the manual button and the ECU, one pole will go to pin 4, the other pole to pin 6. Throw the switch one direction and the manual button does Manual, throw it the other and the manual button will do Power.
Old 11-18-2011, 06:56 PM
B 4 You's Avatar
#lolsvx
that is a good idea, but i am actually just going to install a push button switch for now, because i want to find a shift-lock switch to put where that blank oval is below the shifter, like the japanese ones have. that's my plan at least
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 11-19-2011, 06:15 PM
when i had one (before the new tcu) i used the tcu bracket bolt for ground. worked well.
Old 11-19-2011, 08:18 PM
Originally Posted by B 4 You View Post
Iwant to find a shift-lock switch to put where that blank oval is below the shifter, like the japanese ones have. that's my plan at least
The German SVXs have two switches for this purpose.
On for the Manual control and one for the power antenna.
In fact, the button of the side of the gear selector lets you choose between ECON (normal) and POWER.
Old 11-19-2011, 08:40 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
That is hella cool.
Old 11-19-2011, 09:10 PM
B 4 You's Avatar
#lolsvx
want.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
