cooling fan problem
hi, my cooling fans wont come on. i checked the relay, and its good also checked wiring with a multimeter and voltage looks good. Is there a sensor to engage the fans, thats maybe bad, if so where is it located, and does anyone have any wiring schematics of the svx?
"wow how much money did it cost for you to do that to your windows, thats some pretty custom $h!t" |
see if this helps.. http://www.subaru-svx.net/photos/files/Beav/7752.gif
thanks.. you think it could be that sensor or could it be a big problem
I don't know about the SVX, but on my Dodge the temperature sensor was the problem for the fan not working. If you run out of ideas, you can temporarily install a manual switch to engage the fan when needed.
Specifics
Are you concerned that they do not operate, even when the engine temperature reads as being very high and they should be running? Does a fan run when the air conditioning is operating?
It is a very good bet that the water temperature sensor is faulty. Replace it and fingers crossed.
this would be the same sensor that is linked to the relay that kicks on the fan, which the wiring leads to? thanks for the help
check to see if the a/c fuse in the engine bay fuse box is in, and not blown. Just a guess but easy to check. I think the power goes thru it to the fans. I emphasize on the word think. But if nothing else you can run a wire from there to power the driverside fan all the time while cars ignition is on.
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running |
