Old 10-15-2010, 04:35 PM
zymmer4 zymmer4 is offline
cooling fans stay on
My 1995 ls..the cooling fans stay on continuesly and the car won't start easily when the temperature is below 70 or so..I changed the water temp sensor with a known good one..fans still are on all the time..dosen't want to start easily when cooler than 70 deg F..What might my problem be? ECU?..maybe a relay short??Help
thanks, Howard
Old 10-15-2010, 05:27 PM
oab_au oab_au is offline
Re: cooling fans stay on
thanks, Howard
"I changed the water temp sensor" Was that the one with the single wire or the one with two wires.?
One Arm Bloke.
Tell it like it is!
Old 10-15-2010, 05:43 PM
Is your speedometer working well? If a speed sensor fails your fans will run constantly.
Old 10-15-2010, 08:44 PM
Definitely sounds like a water temp or coolant temp sensor. As Harvey said, make sure you change the one with the 2 prong connector and not the one with the spade type connector.
Old 10-20-2010, 11:34 AM
Question Re: cooling fans stay on
I changed the two wire temp sensor, the cam position sensor, both the crank sensors..the speedo works fine..the tach works fine..those fans just keep on turning..I did notice, this morning, that when I turn the key to "start" position, the clock goes off..never noticed that before..and the time resets..any help?
thanks.
Old 10-20-2010, 08:43 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
thanks.
Do you have anything aftermarket wired into the car?
Old 10-21-2010, 10:41 AM
I have the radio that the P.O. wired in..but the starting problem just started some two years after I bought the 1995 L..I do suspect that the radio is not wired properly because the radio memory is not wired in..I should also mention that I have changed the MAF as well..Is the ECU a suspect in this problem? My code light bulb is burned out ..is the ECU under the dash..on left?
Old 10-21-2010, 10:43 AM
the speed sensors are on the tranny? one near the front..and one near the rear with my 4EAT?
Old 10-24-2010, 01:35 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
The fans always run on mine if the ac is on...
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
