engine skip
I know this has been an issue on others and has been mentioned before but; I have a bad miss (happens more often than not) at idle and in 4th automatic gear below 2rpm. When I'm able to give it more gas and the transmission shifts down and rpms go up, no miss. I have swapped out all coils and changed the MAF. It has been doing this for a very long time and no one can figure it out. Any help would be great. Has anyone had this problem and solved it?
Also every time I drive the car my oil dipstick handle gets pushed up about an inch and sits out of the channel...related? Last edited by cutrell3; 08-21-2008 at 06:35 PM. |
Re: engine skip
but dipstick getting pushed out is ok, i think. i had this problem with my old svx and it was running very fine,before someone steals it well when i found it back i had to do an hg job, i don't know if it was because when they stole it they kicked the ass out of the engine or because it was an incoming sign, sometimes its only the o-ring being tired...
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
Re: engine skip
I haven't had the dip stick problem but I have read here before that it could be caused by a bad PCV valve.
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
Re: engine skip
yeah i remember cleaning the pcv valve could fix the problem, but as for myself it was nothing....
