need info on SVX rods
does anyone know is the eg33 rods are interchangeable with other subies'??
I really need to know, searched the forum without luck. thanksss |
Longassname (LAN) aka ECUTune is having them made for built engines
there is already atleast one SVX runnin them
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
I want to get the carillos. I need to know which subies are interchangeable with the svx rods
i think they started with eg22 rods... check the ecutune threads is what I'm getting at This sort of thing with "rods" and "ecutune"
I know I was gonna try eg22 when I was doing it alone... I'm gonna get them from LAN when I am ready to get back to it
thanks. will check it out
Need for Speed will know, send him a PM.[Private Message] Cool name you picked BTW. Spelling it the Spanish way is a stroke of genius. Joe
actually i also have dis one. can both be merged to become Giugiaro ??
The SVX expansion goes two ways: 1. Horizontal expansion: Multi SVXi 2. Vertical expansion: Fun max from one SVX |
STI rods are the same along with the ej22 rods... Just go ahead and check the specs for the bores and length in your factory manuals
Tom |
You can keep 'em guessing!
Don't have a factory manual... any link?
bottom line, does the USDM STi rods fit instead of stock EG33 rods?
yes.... but since the SVX crank is internally balanced you would want a weight matched set of 6 not just any 6 you can find
Tom |
