af ratio quick ?
what legacy fpr can we use on the svx? part # if possible or year and exact model and price? and is it a tough install any mods or changes? and last i read the maf on our car maxs at 5600rpm or so what would be a good upgrade a wrx one maybe on off a z or some other sports car? i read the wide band o2 thread and im very curious about these mods for a little more power and proformance.
The Impreza RS fpr part number is in my locker.
keep it alive people.
It takes about 20 min to install. The hardest part is getting the fuel lines to come loose. Once those break loose, its 5 min of work.
white grease on the o-ring, make sure not to pinch the o-ring when installing the FPR. A little white grease on the fuel fitting will allow the fuel line to slip on easier (fuel injection line is a lot stiffer than regular fuel line...)
-Bill
i know the filter change was a pain.
