exhaust gaskets
So my exhaust gaskets have ****ted themselves again. Its actually been this way for a while now. I got them replaced by a local garage in januaru of 04....and they crapped out shortly after for some reason. Car just sounds bad when u get on the exhaust. So how much are the gaskets and how easy or difficult are they to replace? I'm also going to be getting the magnaflow muffler and cutting out the resonator soon after i get the timing belt...water pump..and front seals done. That local shop told me a yr ago that it had to be heated to put in or something like that i dont know for sure.
If you're talking about the gasket between the head pipe and the exhaust manifold, it's just a split ring of metal - think a larger version of the stock oil pan drain plug gasket - that fits in the stepped part of the exhaust manifold. The head pipe actually slides into the exhaust manifold and crushes the gasket when you tighten the two bolts/studs.
-Bill
Thanks bill, you know why it would make bad noises if it went bad? Ive always wanted to know. Tom told me that their made out of lead which is why they go bad so quick.
Some gaskets cost more than others. The two gaskets that connect each exhaust manifold to the head pipes (part #44022AA200) are pretty cheap at ~$6 each. The one gasket that connects the stock muffler to the pipe coming from the resonator (part #44022PA000) costs close to $50 from subaruparts.com! http://www.subaruparts.com/diag/?mod...category=440-A -Chike
Change?
If it was a southern or western car they would be fairly easy to change, but as a northern car I bet all the bolts are rusted and will probably break when you try to take the nut off. You will probably have to replace the bolts.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
