Old 10-17-2005, 09:00 PM
elvis elvis is offline
Lazy Sunroof
I know this is a known issue, but I can't seem to find out what the deal is.
If I wanted to actually spend the money and time to fix the "I have to push the sunroof open 1/4 way before it opens itself" problem, what I am I looking at replacing?
Thanks in advance.
Old 10-17-2005, 09:06 PM
I think one of the easiest ways out is to lube up the rails with graphite dust or summin'.
Nothing else short of replacing the motor.
Old 10-17-2005, 09:07 PM
pipedream's Avatar
pipedream pipedream is offline
Send a message via AIM to pipedream
Yeah, this would be cool.
Although, I'll admit I've become pretty suave at being able to make it look like it's actually opening by itself with the 'ol one handed button and simultaneous top push.
Old 10-17-2005, 09:21 PM
kuoh kuoh is offline
I can think of something a bit shorter than that, like tightening up the clutch nut.
KuoH
Old 10-17-2005, 09:31 PM
Silicone spray is a much better product to use for the lube.
Old 10-18-2005, 12:41 AM
KuoH
There's a clutch nut?
Well mine works fine.
Never had to goof around with it.
Old 10-18-2005, 07:03 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Here is an excellent review of this recurring nightmare.
http://www.subaru-svx.net/forum/show...sunroof+clutch
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-18-2005, 07:09 AM
It's the only thing I'll use! Petroleum based gaskets aren't too keen on petroleum based lubricants in the long term.
Robert
Last edited by Electrophil; 10-18-2005 at 07:10 AM. Reason: "think"="thing".. Fixed it.
Old 10-18-2005, 10:23 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I found that if you completely remove the sunroof you'll find a number of small white bushings that have disintegrated. I replaced them with regular old aquarium air tubing, cut to fit. Lubed with a silicone grease that doesn't attract dirt. I did this around May or June and so far, using it several times each day, it works flawlessly.
Old 10-18-2005, 10:56 AM
SubaruPartsGirl SubaruPartsGirl is offline
Parts Hook-Up
I would have to agree that sunroofs can be a problem when they no longer operate properly. If your not willing to crack it open and take a look, there are many upholstery or glass shops that are willing to repair it for a reasonable price depending on what the problem is. There are tons of tiny moving parts in there that get dusty, chewed up, and worn out.
Jackie
Old 10-18-2005, 05:25 PM
immortal_suby's Avatar
Thread Killah
I'll vouch for that. Lube it and do the sunroof clutch nut adjustment - worked for me.
Locker Link
2015 BRZ Limited 6MT
