Old 08-09-2009, 12:27 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Cruise control - not working
OK so know that I have just spent $1k on tires (Falken ZE912) - my cruise control is now NOT working....
Push swich in - hear relay click on (under the glove box area) - but nothing happens.
Is it controlled by Vacuum - if so I may have a leak somewhere not allowing the thing to function, any help would be great...
Steve (1 OF 1) - with only 141,000kms for 1995
Old 08-09-2009, 12:46 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Cruise control - not working
Check this hose
Wanted: Steering Wheel
Old 08-09-2009, 12:48 PM
SURTEESS's Avatar
Cool Re: Cruise control - not working
Michael - thanks for the quick response, will do that tonight.
Steve
Old 08-10-2009, 12:20 PM
SURTEESS's Avatar
OK checked the hose - all fine, no cracks.....so where to now??
Old 08-10-2009, 01:13 PM
michael's Avatar
What Potholes ???
Are you sure the click was a relay and not the switch itself? if it was the switch check the fuse. Does your speedometer work?
Old 08-10-2009, 06:10 PM
SURTEESS's Avatar
Switch working & so is the relay under the dash..........as a side issue what is the "things" at each end of the cruse control hose.
1 is under the fuse box
2 is linked the throttle linkage.
Old 08-11-2009, 12:47 AM
AUSVX AUSVX is offline
Registered Loser
That little hose that michael showed you has to be pushed in until you can feel it clip or bite in there.. then go for a test drive. Clicks should be coming from the passenger side.
Unless you have rats eating your hose you will not have a problem, I thought mine was gone too.
I have a 92 with 240,000kms
Old 08-11-2009, 05:11 AM
michael's Avatar
What Potholes ???
If your speedometer is not working due to a bad of non working speed sensor your cruise will not work either. Check the cable next to the throttle cable on the throttle body too.
Old 08-11-2009, 12:20 PM
SURTEESS's Avatar
Speedo is working fine - will re-check hose near top
Old 08-11-2009, 05:30 PM
oab_au oab_au is offline
1. Is the vacuum pump and modulator. Controls the level of vacuum applied to., No. 2. The diaphragm that pulls the throttle open.
One Arm Bloke.
Tell it like it is!
Old 08-11-2009, 06:31 PM
SURTEESS's Avatar
Thanks for that - will have to see if the diaphram is stuck........
Old 08-13-2009, 12:35 PM
SURTEESS's Avatar
Thumbs up Re: Cruise control - not working
OK - got it going at last (hate things not working ANYWHERE) ---- I ended up taking the steering wheel indicator area apart & measured the resistance on the cruise control stalk switch - hey NO it was just open circuit all the time no matter what direction I tried, so out came the deoxit, quick spray & working back in a flash, put it all back together & she it so sweet now.
The car is not my DD so figure that oxide buildup over the years finally took their toll.... anyway thoiught I would share that gem.
thanks to all
Steve in New Zealand
(1 OF 1)
Old 08-13-2009, 03:30 PM
michael's Avatar
What Potholes ???
Glad to hear you got it sorted out. Sorry I couldn't be of more assistance. Mine may need the same treatment, you have to click it twice to get it on. Was your light on the button coming on when you heard it click?
Old 08-13-2009, 04:56 PM
SURTEESS's Avatar
yes see early posting....
Old 08-13-2009, 09:17 PM
McTaff's Avatar
McTaff McTaff is offline
Mr Soob
Unrelated issue:
In the dash (under the instrument cluster) the button to hit to enable the cruise control is not 100%...
It's a 'toggle' switch but without a micro... generally, you push it in and it goes ahead and lights up. Now for quite some time I find I have to push it several times because when I push it in, it lights up, but switches off as soon as I let it go.
It's almost as if it's either thinking I've pressed it twice (i.e. it travels too far and registers as two 'pushes') or it is tripping out. Usually a couple of pushes and it stays on.
It's bothersome, but it's not the end of the world. I haven't taken it apart to really look at it, but I figured I'd throw it out there now that Surtees is all good, and see if anyone else has had the same problem and if/how they fixed it.
'07 Outback (Legacy) Pearl White > 3.0R Premium, stock (50,000km, Wifes daily driver. Owned from new) Not For Sale
'92 SVX Black on Pearl White > 6spd, DCCD on the way. (260,000km, My daily driver, 2 previous owners) Not For Sale
'93 SVX Black on Charcoal > Aftermarket rims.(250,000 km, Dad's daily driver, unknown owners) Not For Sale
'93 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (55,000km, 1 previous owner) Not For Sale
'92 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (144,000km, 2 previous owners) Not For Sale
Wife, Red Hot when riled > Treated like a princess. Minister For Finance, Domestic Affairs and Diplomatic Relations. Definitely Not For Sale
My Wanted List: http://www.subaru-svx.net/forum/show...178#post632178
