The roads are so bad....
The roads here are covered with ice. Its like driving on a sheet of ice...some trucks have laid some salt down but it does no good. I almost skidded off the road 30 times on my 5 mile trip home from work. This car is a heavy slug to stop . Glad to be alive!! oh and by the ABS sucks and makes the car wanna skid more...do your self a favor...pop the car into 2 and hit the trusty manual switch.
I drove out after an ice storm years back where just the crown of the road was enough to start the car sliding towards the gutters and the SVX acquitted itself quite well, especially considering it was only equipped with well used all season tires. Getting started wasn't a problem, but you had better know well in advance where you wanted to slow down and turn or stop. I saw many many vehicles slide through red lights and stop signs that morning and was lucky enough not to be rear ended or T-boned. Driving on ice takes planning, patience and a good bit of luck, because even if you manage to avoid running into something, you still have to worry about other cars running into you.
Honestly, I doubt any other 90's ABS system designed in the 80's would cope any better on pure ice. I'd have to wonder if even todays ABS systems would show much improvement on ice? Unless it is augmented by some sort of inertial or radar sensor, just relying on wheel speed sensors alone probably isn't going to be reliable enough. KuoH Quote:
It's all in the tires.
My ABS functions superbly, when it functions. However, my tires grip the ice somewhat well while slowing down, so I almost never use it unless I want to show off.
I never figured out what the manual button does.. or the shift lock one.
Brian |
Shift lock allowsyou to select a shifter positon from park without pressing the brake pedal for example if your battery dies in park, and you need to shift to neutral. Also useful if you like pushing your car around instead of turning it on all the time.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 12-15-2005 at 09:18 PM. |
Don't get too overconfident in those tires unless they're the 007 variety with on demand spikes. The differences in the types of ice you encounter matters more than the brand of tires. On "sticky" ice, where there is a nice relatively grippy layer of frost that could permafrost your tongue to the pavement, you have a good chance of stopping under full control if you're careful. Wait until the sun comes out or the temperature rises near the freezing point and starts melting that top layer, and your chances of shortish controlled stops goes right out the window.
KuoH |
Glad you're safe Tom. AWD definitely doesn't make you invincible out there even with a good set of snows!
-Chike
I dont light up the front tires ever even when i floor it in the rain or from a stop. But for some reason it feels like its not working as it should. I was stopped on a hill waiting for a truck to pass by so I wouldnt get salt thrown at my car...and when i gave it a good amount of gas the car slipped then the rear kicked in...i mean it was really icy so that had to be why. Ah well whatever
MY point is the ABS only works as well as your tires, because it only functions under the conditions they fail.
