Automatic Transmission Parts For Sale
Not that many of us do transmission repair, but if you are, I have the following Automatic transmission parts for sale.
Please PM me if interested in any transmission parts, other then forward clutches. Here are just some of the items. All are in perfect condition. The diff is gone. - Torque converter - Trans Resistor (behind battery) - Shift Level (interior) - Trans Computer - Shift cable - All solenoids - Transmission pan - Dipsticks for Diff and trans - Switch on trans for (P-R-N-D-3-2-1) - Brake Band Assembly - Valve body - Trans Extension (Speed sensor, Transfer Valve) - Clutch Drum assembly - Oil Pump - All gears - Reverse Clutch Assembly - Differential case - Input Shaft - Differential gear and transfer (pinion) gear - SOLD Thanks Last edited by svxcuseme; 05-18-2006 at 03:52 PM. |
Do you have the rubber transmission mount? How much?
how much for sol. C... i think it should fit a legacy...
Sorry for not getting back on this until now. PM Sent
Still for sale ...
- 1992 - SVX Drive Shaft
- 2002 - WRX Drive shaft - Torque converter - Trans Resistor (behind battery) - Shift Level (interior) - Trans Computer - Shift cable - All solenoids - Transmission pan - Dipsticks for Diff and trans - Brake Band Assembly - Valve body - Trans Extension (Speed sensor, Transfer Valve) - Clutch Drum assembly - Oil Pump - All gears - Reverse Clutch Assembly - Input Shaft - NSS Switch on trans (P-R-N-D-3-2-1) - SOLD - Differential gear and transfer (pinion) gear - SOLD Last edited by svxcuseme; 08-23-2006 at 06:57 AM. |
Bump ............ Still for sale
