Old 03-24-2005, 07:01 PM
RobSVX
Leaky 'Plate' between Engine and Tranny ?
Hey,
I took the car to the dealer for an Oil Change and Checkout (had a coupon). He told me, there 's some plate that's leaking and sits between the engine and tranny ?
Since I wasn't dumping the cash into it (its 10 years old so waste of $), I'm curious what the heck he was talking about ? I know what a rear seal is, but that's not a plate...
Thoughts ?
-Robert
Old 03-24-2005, 08:06 PM
lee lee is offline
the only "plate" in there is the flex-plate, and yes, it would probably be a rear main seal to be leaking oil there. A much less likely cause (IMO) would be a leak at the tube that seals the differential from the input shaft (between torque converter and tranny). That would mean the leak was Diff fluid, and a simple smell test should eliminate that as a choice. Lastly, I suppose the seal at the input shaft of the tranny could be leaking and allowing ATF to migrate up inside the tube mentioned before. This of course would mean red stuff coming out.
Old 03-27-2005, 12:40 AM
THAWA
Probably meant the separator plate. It's allows access to the right bank of pistons for removing pins and whatnot. I think it has another purpose aswell, but I don't know what it is off the top of my head.
Old 03-28-2005, 12:42 PM
red95svx
Originally Posted by RobSVX
Hey,
Thoughts ?
-Robert
It's called the oil seperator plate. Pretty common to replace on older vehicles. The part is relatively cheap, but the labor is costly as it involves removing the tranny. Like THAWA, I'm not real sure what purpose it serves.
Old 03-28-2005, 12:56 PM
svx_commuter's Avatar
The separator removes the oil mist from the air moving to the PCV valve before entering the engine. It is not visable from underneath the car because it is in the space between the engine and tranmission and behind the flex plate.
What ever is leaking may slow down if you add some Lucas Oil Stablizer. It has helped a lot on my engine.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 03-29-2005, 09:26 PM
RobSVX
Thanks guys... Once again, I get the right answer !
Atleast I know what he meant...
I'll check out the Lucas Oil Stabilizer product.
Old 03-29-2005, 10:53 PM
It is a plastic plate on the back of the engine which is replaced later on by an aluminum plate. the plastic one must be cracked, like the case was with my car, i had to buy another one from the dealer (i think for either $35 or $50) and change it.
Old 03-30-2005, 03:20 PM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
Funny you should mention
that plate. I just had the rear main seal replaced, and did the plate at the same time.
Since I work for Subaru, I got a good deal on the parts, but here's the part number if anyone needs it:
11831AA150
Retail: $18.86
'92 SVX LS-L
Project Car for Open Road Racing
Old 03-30-2005, 10:51 PM
11831AA150
Retail: $18.86
Roo, is it plastic or aluminum??
Old 03-31-2005, 08:09 AM
Roo Roo is offline
The part...
The part is aluminum. The original plate was plastic, and they found it to not be stable/durable enough. They changed it out for aluminum.
'92 SVX LS-L
