Proactively Replacing 02 sensors... Is it a waste of money?
Hello all,
My 1996 has 115K miles and I don't think the O2 sensors have ever been changed. I have no indicators that they are defective, I was just thinking that they need to be replaced at about 100K miles. That being said, should they really be replaced proactively? Thanks in advance. Clarke |
Re: Proactively Replacing 02 sensors... Is it a waste of money?
You are doing the right thing..your gas mileage should be a bit better too.
I don't normally do mine unless it throws a code. If you haven't done so, put some antiseize on the threads. |
i need to get new ones on mine.
procrastination.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Put new ones on mine proactively. Figured it could only help.
I wait for a code. If they aren't working properly the CEL will let you know.
If you're seeing no symptoms, I really see no reason to replace them. Now, if you were having bad mpg or other engine issues, then I could justify replacement. But, "just because it's old" isn't really a good reason to replace things on a car unless it's prompted by something else, or it's something that wears out with age (belts, gaskets, etc.)
If it aint broke, dont fix it. If it broke while you were fixing it, it needed fixin' anyway!
2010 Subaru WRX 1992 SVX LS-L 89k miles-SOLD! KTM 250sx MX bike aka "Killer Pumpkin" |
recover horsepower and drivability by switching to denso 02s.. $60 each at rockauto
I would proactively replace O2 sensors (or pretty much anything else) only if a failing O2 sensor could make me have to walk home.
dcb |
