Old 05-02-2017, 12:18 PM
Huskymaniac's Avatar
Uses the ignore feature
Need front caliper bolt ASAP!!!
Somehow, one of my front caliper bolts was missing.
Can someone get me the specifications on the bolt or the Subaru part number?
Tony
Old 05-02-2017, 12:26 PM
processengr's Avatar
Re: Need front caliper bolt ASAP!!!
I'm thinking it is Subaru 901130011 Disc Brake Caliper Bracket Mounting Bolt.
You can get these from a Subaru dealer on Ebay at a discount.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 05-02-2017, 12:33 PM
I looked that up and it is not the right one. The one I need is what I believe is called a carriage bolt. It is long and has a large area that is not threaded. It acts as the slide on the side opposite the guide pin.
Tony
Old 05-03-2017, 02:59 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
http://subaru.epc-data.com/alcyone_s...ns/262/26288B/
Old 05-03-2017, 08:25 AM
Originally Posted by SURTEESS View Post
Thanks but I actually need 26288A and I ordered it along with the sleeve and seal kit. No idea how that bolt unscrewed itself other than, maybe, it wasn't tightened enough.
I will also say that I will never buy slotted rotors again. This time around I am going with cross drilled. I am not sure even that is necessary. I also discovered that you can now get cryo treated cross drilled rotors from stoptech but the lead time was too long and I need my car back on the road ASAP! But, actually, solid cryo treated rotors with Akebono ProACT pads worked well on the Tribeca in terms on not getting "warped" so that is probably sufficient.
Tony
Old 05-03-2017, 08:44 AM
SVX_MY_BABY's Avatar
cryo treated
Try ART, Applied Rotor Technologies.
I'm on my second set and very pleased. Quick shipping.
http://www.subaru-svx.net/photos/fil...BABY/4388.html
Peter
