Need front caliper bolt ASAP!!!
Somehow, one of my front caliper bolts was missing.
Can someone get me the specifications on the bolt or the Subaru part number?
Re: Need front caliper bolt ASAP!!!
I'm thinking it is Subaru 901130011 Disc Brake Caliper Bracket Mounting Bolt.
You can get these from a Subaru dealer on Ebay at a discount.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
I looked that up and it is not the right one. The one I need is what I believe is called a carriage bolt. It is long and has a large area that is not threaded. It acts as the slide on the side opposite the guide pin.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
I will also say that I will never buy slotted rotors again. This time around I am going with cross drilled. I am not sure even that is necessary. I also discovered that you can now get cryo treated cross drilled rotors from stoptech but the lead time was too long and I need my car back on the road ASAP! But, actually, solid cryo treated rotors with Akebono ProACT pads worked well on the Tribeca in terms on not getting "warped" so that is probably sufficient.
cryo treated
Try ART, Applied Rotor Technologies. I'm on my second set and very pleased. Quick shipping. http://www.subaru-svx.net/photos/fil...BABY/4388.html
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. Last edited by SVX_MY_BABY; 05-03-2017 at 08:52 AM. |
