Re: 24 hours of Lemons... Car suggestions???
Pick up a Turbo XT with a blown head gasket, and fix it... They can be had for cheap....
Turbo K- Car Yo!
Edit: Argh I posted as Tom... -Mike |
even a beat up DSM with a bad head will cost 1000
I really want to know what car you will be getting for 500.
Mike 1992 SVX LS-L Pearl White 102,000 miles (Gone) 2005 Evolution 8 SSL Tarmac Black (new daily) 1995 Eclipse GSX Durango Copper Pearl (teh beast) 276awhp/280awtq @ 18psi (560's inj) 260awhp/260awtq @ 17psi (stock inj) |
Thunderbird SC. Factory supercharged, 325lb-ft of torque, RWD, IRS, very easy to make them carve corners extremely well, and as long as the headgaskets are done, it will be as reliable as the day is long. If you find one with blown headgaskets and a trashed interior, you can probably pick it up for $300. Replace the head gaskets and use studs instead of bolts, and MLS gaskets. Also make sure to get one with a 5-speed as there is no way the AOD will make it 12 hours of beating on it. Try to get an 89 or 90 as they have the stiffest sway bars. Cut one coil off all 4 springs, and make sure all the bushings in the suspension are good, and get some weight off it, and it will outhandle everything else on the track.
MY TOYS 95 SVX 98 Lincoln MarkVIII LSC, 5-speed swap 91 Marcury Cougar, 393" stroker, completely insane! 89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt. 80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished. |
I've spent some time in a Volvo 740 turbo and it wasn't much for corners I like the turbo idea, will this be on a road track or a circle track? Circle track I'd focus on power, road track I'd focus on handling...and I'd drive a BMW e30
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
I believe circle track....
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Do you have a link to the event ? sounds interesting.
good luck!
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue |
i have a 92 ls i picked up for $400 with no title. it needs brakes and a radiatior
i was thinking about using it |
Poor SVX
I'm sure I don't need to plead with ya to recycle everything off the body you can but let me know if you go with it. I got the place for you to get your cage from.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
That's interesting. If they think you spent more than $500 on your car they can vote to crush it.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
#28
Turbo Volvo, boost the chidit out of it
#29
i bought it for spare engine and transmission parts i'll let you guys know if we end up using it |
#30
thanks for the link!
