Old 08-07-2009, 05:38 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Overheating Motor
Bump i'm going to do this within the next 20 min.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-07-2009, 05:54 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by TomsSVX View Post
Yes, but sometimes the switches stop working like they should Just had one doing it the other day.
Yup! Is pretty easy to tell after 50 years in refrigeration
Does take a while...
Keith
Old 08-07-2009, 05:56 PM
kwren's Avatar
Originally Posted by redlightningsvx View Post
Got a new OEM thermostat and gasket today at work, plus a jug of Subaru coolant. When I do this should I change the fluid or reuse the old and add accordingly? I changed the coolant a little over a year ago.
Would imagine the only people that recommend replacing all the fluid every year would be the people that sell it!
Keith
Old 08-07-2009, 07:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Didnt read this in time...... I would use the entire jug first, then top off whats left with the year-old stuff.
Old 08-07-2009, 07:40 PM
That's exactly what I did. The old Subaru coolant was the green stuff, and the jug of Subaru coolant I grabbed at work was the new super coolant which is blue. I figured they could be mixed together since there both Subaru.
Seth
Past subies:
Other toys:
Old 08-07-2009, 10:01 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Ooh I didnt know that, they say you're not supposed to mix them...... not dangerous or anything but it supposedly negates the extended life protection of the super-coolant. I think it would be kinda cool to have all blue coolant though.
Old 08-09-2009, 10:43 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
What was the thermostat like? Another board member recently got a new Subaru thermostat, it is very small & cheap looking made of thin brass. It looked to be nowhere near the quality of the original or even as good as the cheap aftermarket ones?? It did have the "fuji swoosh" stamped on it though??
Old 08-10-2009, 04:06 PM
It looked the same as the old one.
Seth
Past subies:
Other toys:
Old 08-12-2009, 07:05 PM
Update: It hasn't overheated since the thermostat was replaced but now the coolant is filling up past the full in the overflow tank and not draining out back into the radiator. I no for a fact there isn't a blockage in the hose or tank as I cleaned them really good. So know I ordered a new radiator cap so hopfully this solves the problem.
Seth
Past subies:
Other toys:
Old 08-12-2009, 07:25 PM
contraction leak might also be worth while but they are hard to troubleshoot. Need a cooling system Vac/filling tool but even then finding the issue is tough. Didn't you have that engine diagnosed with a HG failure a while back?
Old 08-12-2009, 07:29 PM
No i never had it diagnosed for a HG fail as it didn't eat coolant, no oil contamination, white smoke.
p.s. My subie mech at work said the rad cap could be froze where the little silver circle on the bottom lets the fluid back in the rad.
Seth
Past subies:
Other toys:
Old 08-12-2009, 07:31 PM
They rarely do. Typical HC leak will push coolant out of the overflow and leave a large amount of gas in the radiator.
Old 08-12-2009, 07:36 PM
Well the rad cap should be in tomorrow so i'll see how it goes then go from there.
Seth
Past subies:
Other toys:
Old 08-12-2009, 07:41 PM
I will bring up the part# for a good vac/fill kit if you are interested and cannot find someone with one
Old 08-12-2009, 07:45 PM
Link to Snapon
This is the one I have and it works very well
