Retro fitting radiator. Details inside.
Yesterday as i was driving my car was overheating. After i pulled over to the side of the road, couple seconds later BOOOOOOMMMM!!! Yes it was a mess, so i waited to cool off and wasn't far from home, so i babied it home. So i pop the hood open, and what do i see big split across the radiator. So today i called about 20+ junkyards to see if i can get a used one. No luck and on tight budget i wasn't about to give up and spending alot of money on a new one. So i went to the junkyard and walked around for a while looking at different radiators on different cars. I came across the closets radiator of a Toyota Corolla. So today i spent 2 hours on retro fitting one in my car. I will keep you posted on how it goes and the out come. I will post pics up on the setup i used. I had to take one of the radiator fans out because of clearance issues i ran into. Well this only temprorary till i find one. Its very close to the SVX one but dirrent hose size, and tranny fittings. I will stop a Home Depot to pick few more items then it should be complete.
I can't help but have some misgivings about this. First, the Corolla can't require near the cooling capacity of our 3.3L motor and the trans "fittings" you refer to would be cause for some concern as well. I hope you have an auxiliary trans cooler. As far as the 2 fans being reduced to one, please be aware that one of the OEM fans is activated by the A/C. I hope you pulled the "right" one, when in fact, you need them both for proper operation and engine longevity.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
I would have the same concerns. For a Temp Fix, you could be doing some Long Term Damage.
I would worry about the cooling of the tiny Corolla Rad. As sad as it may be it might be better to park it and buy a new Rad when you have the $$$. But then again you could prove us wrong. Let us know how it turns out.
1992 SVX LSL Peacock 94,000Miles 1981 VW Westfalia 166,000Miles 1995 Volvo 850 Wagon GLE 174,000Miles 1981 FIAT Spider 120,000Miles 50% Boxer |
The corolla radiator is the same size maybe off by an inch. I have one of the radiator fans hooked up to a manual switch. It fits into place no problem. So the only thing i have to do is hit the switch when i start the car. As for the tranny cooler. I am going back to the junkyard to pull a tranny cooler of a truck. So that basically covers it.
The Corolla radiator will be rated to remove the heat caused by a 120 hp engine, maybe less. The SVX radiator is rated to remove the heat from double the hp. Two radiators of similar or even the exact same size can have very different cooling capabilities, based on the number of liquid columns and the area of metal that the air flows through. I would not use it as a long-term fix, but the best of luck anyway. Joe
Glenn
The top neck cracked in half on mine today and I just moved the clamp a little further up to 1/8th inch from the edge of the hose and rad. Fans always on at the same time... speeds can't say. Saturns and Hondas(at least some) will kick on one fan at a time.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
120 miles and no problem or over heating. Seems to works just fine.
