Old 02-08-2009, 12:14 PM
Wikedjuggalo's Avatar
Rebuilding
Strange new problem
Okay, well after calling OT and not being sure I figured I'd ask the network. My car has been out of commission for a month after my last over heating issue. Well today I was going to repair the necessary thermostat but decided to check my fluids. Now I didn't loose much coolant but my oil was low. I unscrewed the oil cap and got a nice big whiff of exhaust fumes. What in the world would cause this.
Please feel free to post any ideas to which you think it might be
Also... I had a nice look in my overflow tank and got this
Old 02-08-2009, 12:23 PM
SuberNatural SuberNatural is offline
Re: Strange new problem
Are you sure it was exhaust, or was it the smell of burnt oil? If you oil was low enough and your motor got hot enough it could cause some vaporization of the oil. Is your oil REALLY dark or anything like that?
When I once had a headgasket cause some overheating when I opened the filler cap on the VC there was a little 'smoke' if you will from the vaporization.
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 02-08-2009, 12:26 PM
Rebuilding
No, I know the smell of burning oil and I had two other people smell it and concur with me it was exhaust.
Old 02-08-2009, 01:35 PM
Thats probably blow-by then. Exhaust gasses getting past worn rings and into the crank case.
Old 02-09-2009, 03:31 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I'm no mechanic, but overheating, exhaust in the oil and gunk in the coolant sounds a lot like headgasket failure.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 02-09-2009, 03:34 AM
Rebuilding
Aye. it could be but its adding up more to be worn rings then head gasket. The coolant/oil hadn't gone down or missing. I have a feeling I will end up pulling the engine and doing an engine swap/rebuild :/
