Fuel Pump Question
If you had low fuel pressure....
what kinda symptoms would you have ? thanks guys ! |
Here is the general trouble shooting chart. Check your current system against the chart. It may help point you to your problem.
what is the "MPFI System"
thats what I thought... but on the SVX ya never know..
could have been the M)oldy P)ork F)ood I)odizer heheh |
My cars fuel pressure it running right under specs..
I think the low went is supposed to be 27psi, and mine at the high end is running around 25psi... is it possible to have almost enough pressure, but the flow still be chocked off.. cuz Im wondering if I dont have a bad fuel pump / regulator, or a cloggged fuel line.. |
Silly question...
but have you replaced the fuel filter? It only takes a couple tanks of sludge to seriously reduce fuel flow.
Todd
Down to none |
that has not been done...
I think Im going to take it in again.. have them change the filter.. and then test it again... the car is getting so bad... if you take off from a stop.. the car cant rev over about 5500rpm... and just revs there.. rrrrhhrrrrrr.. rrrrrhhhhrrrrrr.... kinda bounce up and down from 5300 to 5500 doesnt ever get high enough to shift.... |
hmmm...now that you mention that, another member had a part of his exhaust fail and cause a similar problem...wouldn't rev over a certain RPM.
well, just yesterday.. I had new cats installed (they were partly clogged)
and the muffler checked... everything in the exhaust is ok now.. I have had EVERYTHING checked.. took it to the tranny shop.. its ok had the timing check.. the TPS checked. .. new spark plugs.. new timing belt.. had each cylender checked for compression.. Im going to take it up to subaru.. and have them check the fuel pump/filter/regulator.. thats the only thing left... if thats not the problem.. I donno what to do.. |
OK, my poor car is sitting up at subaru.....
I will find out next week, what they say is wrong with it.. cross your fingers for me ! |
I bet it's
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
