Old 10-26-2010, 10:41 PM
Black88GTA's Avatar
Black88GTA Black88GTA is offline
look like a leprechaun to me
Crank pulley wore through belt cover?
So after lots of swearing, I finally have my motor out of the car to replace my bad head gasket. When tearing into it, I found that my crank pulley has worn through the timing cover plastic! I know this can be caused by a stock pulley separating and wobbling, but this car has been running a one piece Perrin aluminum pulley since last summer, and it certainly wasn't like this when I installed it! Anyone know what might cause this, or how I can fix it? I was thinking about putting a couple washers directly behind the pulley to space it out enough where it won't rub when I reassemble it.
Also, does anyone have a center timing cover for sale?
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road.
Old 10-26-2010, 11:54 PM
This happened to me when I installed an aftermarket pulley. The problem was solved when I had a stock pulley installed.
Check the pulley key slot for wear.
Old 10-27-2010, 05:01 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Crank pulley wore through belt cover?
Don't use washers to move the pulley. It will move it out of alignment with the other pulleys that it drives.
Old 10-27-2010, 05:33 AM
SomethingElse's Avatar
word words wording
The plastic cover warps and the the piece behind it does too.
Eric
Old 10-27-2010, 08:14 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Mine is just like this one.... Like SomethingElse said, it just warps and slowly gets rubbed thru.
Old 10-27-2010, 11:44 AM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Mine is also like this on my red car. It also has wear and holes from when the timing belt exploded 5 years ago. I have been running without any problems since then with the battered cover, its not a "holy crap how do I fix this?" Type of problem. When my water pump went a couple years ago, the timing belt was still in good enough shape for me to reuse.
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 10-27-2010, 12:48 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Sunvisors that won't stay up, sunroofs that won't go up, bearings that roar, pulleys that cut.
Old 10-27-2010, 03:51 PM
sd2649's Avatar
Driving in Style
Gosh, way to be a downer!
I have a theory about those rear bearings... has anyone actually seem the bearings upon removal? Did they really fail?
Only reason I ask is, I have never heard of one failing completely, I did hear the dreaded roar though, pulled the tire, brake assembly and rotor and the thing seemed really tight and smooth, when I put it back together, I greased the brake caliper slides and the noise went away for months, when it came back, I replaced my warped rear rotors and it has been quiet for 3 years or so...... just saying... also, if you drive upside down, the visors arent a problem either :P
-Steven
SOLD
Old 10-27-2010, 07:47 PM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
In my H6 Outback the stock rubber/metal pully started to seperate and cut almost through the METAL timing cover. Only made noise on very hot days under load... took a little while to figure out.
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 10-27-2010, 10:44 PM
Black88GTA's Avatar
Well, hopefully it's just warped plastic and nothing to worry about...at least it seems I'm not the only one, at least. If I replace this plastic part with a new one from Subaru, could I expect the same thing happen to it? I know I could run with it as-is, but I'd rather not. It bothers me like that.
Someone on another forum was saying that it could be either a worn out pulley, worn out crank keyway, or crankwalk. The pulley and crank snout keyway look fine. Has anyone experienced crankwalk in their SVX?
Old 10-28-2010, 07:25 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
With seven main bearings on a 3-cylinder long block, and 180' piston opposition.... I would assume our engines are pretty immune to it.
Old 10-28-2010, 08:26 AM
Not when you wear out your thrust bearing. Been there.
I've bought a few of these covers new from Subaru. They come with new gaskets for them as well.
Old 10-28-2010, 09:15 AM
sd2649's Avatar
Driving in Style
The wear on mine was on that same side, and wore the same way, I wouldnt be worried about any issues with your engine. Just my two cents
-Steven
SOLD
Old 11-18-2010, 03:20 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
My '92 - with a used '92 engine with 115K miles on it - did the same exact thing on the timing belt cover. The pulley was LOOSE - finger tight. Rattled badly when the engine was cold, causing me to think I had a engine bearing that was bad. SVXFILES found the problem and replaced the pulley. While replacing it, he discovered that the "key" and keyway in the pulley were very worn, so be sure to replace the key.
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 11-19-2010, 01:50 AM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Same here... same spot... ugh.
1994 subaru svx le 112k
